How do sew buttonholes Brother
Easy Buttonhole Tutorial
Buttonhole Blah sewing discussion topic PatternReview com
RenaissanceFestival com Forums
Manual:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0ahUKEwjF7pOfzKrYAhUBXGMKHaXRAfkQFggnMAA&url=http%3A%2F%2Fdownload.brother.com%2Fwelcome%2Fdoch000253%2Fxl6452im01enfres.pdf&usg=AOvVaw2RkscYasPZTFlLBOOzY8EK
Hello in some machines its says it makes button holes yes it will but you may have to top change it to do the ends the change it again so it goes down the other side sorry this might be your case just try it and see
SOURCE: How do I change the stiches?
You can do all of these stitches by using different combinations of your stitch selector, stitch width and stitch feed knobs, for instance, on the panel I can see on your machine:
http://www.jo-ann.com/joann/product/images/52659.jsp?CATID=cat3122&PRODID=prd11333
Stitches 1, 2 & 3 are straight stitches, centered, left and right. Really basic stuff, not different stitches at all. 4,5,6,7 & 8 are zig-zag stitches of different widths. 9 is the widest zig-zag (no. 8) on a finer stitch length, etc...
I think you should try and get an instruction manual for your machine. After a lengthy search of my usual manual sources, I've determined that that this may not be so easy. I think you should contact White on their 800 number and let them try and help you... 1-800-331-3164.
If you found this helpful, please vote generously as I receive nothing other than acknowledgement for my time.
SOURCE: I need instrutions on how
hi hrkids
will anything thing here be of help XL-2600/2600i/2610:
riz.
SOURCE: buttonhole on second side was only half the length of first side
Hi, did you buy the machine from a dealer - if so, I would take it back and ask them to show you how to do buttonholes again. It is also possible that, although the test buttonholes sewed out correctly, the automatic button sensor needs professional adjustment.
Before going back to the dealer, find the section in your manual that discusses buttonholes and read thru it very carefully. Pfaff machines are not intuitive, and the manual might describe a way to adjust the automatic buttonhole settings so they sew out correctly.
If you need more help, please repost and I'll try to help or put you in touch with a dealer who can help
Good luck, Ginny
Good luck, Ginny
I've been looking too and I found here http://sewing.patternreview.com/cgi-bin/sewingclasses/board.pl?t=18328that you need to put the bar behind the needle threader down. I think they call it a button hole stop? I don't know, but it worked. I didn't even know it existed. But it solved my problem. On my Kenmore it looks like a black lever and you pull it down. It tells the button-holer that you are at the end of the hole and it needs to backup. nifty, kind of.
SOURCE: Buttonholer operation
push the lever back, look at your manual and you will see what I mean. Read the manual and watch the dvd and you will see what you are doing wrong.
