I have the Saeco Vienna Automatica and recently the coffee gounds dumped into the collector tray are very wet. Before the dumped coffee was a very dry cylinder of coffee. I think this may have changed after I changed the grind setting to 3 but I don't know for sure. Can you help me?
sounds like your pump. When you turn steam knob on, you should hear the pump go bump,bump,bump. When hot water is turned on, you should hear pump run steady.
it is not a filter but a water softener and no need to replace. You need to pass thought it 2 spoon full of salt desolve with water and then flush it with water for 15 min until the salt will be cleaned. You can do this one time per month so to avoid any scale build inside the machine.
If you push the power button and the machine will not turn on and it a newer machine there is a reset button on the side of the boiler that needs to be pushed. This will get you [power again. If the machine is older than 3 years you probably need a new board or power filter.
Clean the ball and valve assembly located in the Brew Group. It ocassionally gets "dirty" and needs cleaning. Be careful you don't lose the glass ball which is very small. Use a q-tip or small wire for cleaning the tubular area.
0 is the finest setting. If you read the manual, it advises to adjust your grinder ONLY when the grinder is actually working. Also, you should only adjust it gradually from one setting to the next (ei. from 2 to 3), and wait about 5 cups before adjusting the setting again.
