Lenovo ThinkPad X61s Notebook Logo
Posted on Jan 31, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I'm at my nephews, and he has been on my x61, haven't got a clue what he has done, but now locked out and reading 'windows bitlocker drive encryption pin entry' I haven't got any codes or passwords with me, and need to access urgently
Anonymous
Level 2:
  • Expert 52 Answers
  • Posted on Aug 12, 2010
Anonymous
Expert
Level 2:
Answers
52
Questions
Helped
34089
Points
107
Hopefully he created a password during the encryption process.
See this reference to recall the steps for encrypting a hard drive with Bitlocker.
Follow the steps for unlocking your hard drive and you should be ok.
Criosdean
Level 1:
Habit-Forming:
  • Contributor 50 Answers
  • Posted on Feb 03, 2010
Criosdean
Contributor
Level 1:
Habit-Forming:
Answers
50
Questions
0
Helped
23309
Points
70
Sounds as if he may have activated 'bitlocker' on your drive. Ask him for the pin code he used and if you get in disable 'bitlocker'. Highlight the drive in My Computer>right click and select turn off bitlocker.
I hope he remembers the pin code he used!
How do I boot to windows or disable bitlocker?
Anonymous,
Steps to Turn On/Off BitLocker:
Click the Start button to view the Start Menu and then choose the Control Panel option.
The Control Panel window opens up.
Now click the System and Security link from this window.
The System and Security section of Control Panel opens up and you can see the direct link for the BitLocker Drive Encryption.
Click on the BitLocker Drive Encryption and a new window opens up.
By default the BitLocker Drive Encryption is Off for the Hard Disk Drive. Click Turn On BitLocker. If a compatible Trusted Platform Module.
Note: To use BitLocker Drive Encryption, your computer has to meet certain hardware requirements.
Otherwise, this opens the BitLocker setup wizard. Follow the instructions in the wizard. If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
Click Turn Off BitLocker. This opens the BitLocker Drive Encryption dialog box. If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
tip
How to Recover Data From a Disk Encrypted by Bitlocker. Data Recovery.
Today we will describe the procedure of data recovery from a damaged disk encrypted by Bitlocker. Such problem may emerge as a result of damage to the file system of an encrypted disk (for example, damage to the area of the hard disk, where BitLocker stores important data, that happens due to unexpected system shutdown), inability to load OS or BitLocker recovery console, and other similar errors that prevent normal opening of the encrypted disk. The described problems may affect both system disk,portable external drive or USB drive.
In order to recover data we will use the utility Repair-bde (BitLocker Repair Tool), a command prompt utility which appeared back in Windows 7 / 2008 R2. This utility is used for access and recovery of encrypted data in a damaged disk encrypted by BitLocker.
Warning. This procedure should be applied after all the others have failed, and it was impossible to unlock the encrypted disk in a standard way by using a Bitlocker password or recovery key.
Requirements for data recovery from a BitLocker volume
To recover data from a disk encrypted by BitLocker you need to have at least one of the following Bitlocker defense elements:
  • BitLocker recovery password;
  • Recovery key;
  • System startup key (Startup key - .bek).
Data will be recovered to a separate disk the size of which should be no less than the size of the damaged disk. In the course of recovery, all contents of this disk will be deleted and replaced by decrypted data from the Bitlocker volume.
In our example, disk E: (size 2 Gb) is a USB drive the contents of which are encrypted by BitLocker, and which cannot be opened for some reason. To recover data, we have installed an additional external disk F: (size 16 Gb).
http://www.fixya.comwrite_tip-wyytcj10vubwvpdmj0eoj2yx-1-9.png
Method 1. Data recovery with the use of a BitLocker password
In the first place, try recovering data with this method (it will work with Windows 8 / 2012 and newer versions):
  • Launch command prompt as administrator.
  • Execute the command:
    repair-bde E: F: -pw -Force
    where E: - disk with Bitlocker data, F: - disk where decrypted data should be extracted.
  • In the course of executing the command you will have to specify BitLocker password (the same which a user is to enter into UI when trying to access an encrypted volume).
  • http://www.fixya.comwrite_tip-wyytcj10vubwvpdmj0eoj2yx-1-2.png
Method 2. Decryption of a Bitlocker volume with a recovery key
For decryption of data located in a damaged volume which is encrypted with Bitlocker we will need a recovery key or a system startup key (if the system partition is encrypted).
Advice. BitLockerRecoveryKey is a unique sequence of 48 symbols. The recovery key is generated when a Bitlocker volume is created; it can be printed, saved as a text file to a local (this choice is not recommended) or external disk, or in a user account at Microsoft website.
http://www.fixya.comwrite_tip-wyytcj10vubwvpdmj0eoj2yx-1-0.png
Now let us launch data recovery with the help of this key:
repair-bde E: F: -rp 011407-712393-682121-100210-377003-405174-520014-328130 -Force
If Bitlocker is used for encryption of the system partition containing Windows, and for loading the system a special startup key on a USB drive is used, the encrypted volume can be decrypted as follows:
repair-bde E: F: -rk I:\3F558473-943D-4330-8449-62C36BA53345.BEK -Force
where file 3F558473-943D-4330-8449-62C36BA53345.BEK is a key to launch BitLocker disk encryption on a USB drive G: (by default, this file is hidden).
After the procedure of data recovery and decryption, before opening the disk where the contents of the Bitlocker volume were extracted, it is necessary to run its check. In order to do it, execute the following command and wait until it is complete:
Chkdsk F: /f
Important note. If you failed to recover data from an encrypted disk with the described methods, it is worth trying to create a sector-by-sector copy of the damaged disk with the help of a Linux utility DDRescue (or any other similar utility). After that, try recovering data from the received copy by the following scenario.
Data Recovery Software
We also should notice that exist more common and simpler way to recover files from Bitlocker encrypted storage. These are data recovery software. Of course, not all programs ?an cope in such situation but some of them have required function.
The only thing is that you must have a password to unlock the device which was specified when encrypt.
Then it's simple. Connecting device with the information that you want to recover to your computer and getting message.
Further, enter password in a special window after double-clicking on the device you need to recover in "This PC".
After that, the storage becomes fully accessible for data recovery for any of the Hetman Software programs.
tip
In this article we will describe the procedure of data recovery from a damaged disk encrypted by Bitlocker. Such problem may emerge as a result of damage to the file system of an encrypted disk (for example, damage to the area of the hard disk, where
  • Recovery key;
Chkdsk F: /f
After that, the storage becomes fully accessible for data recovery for Hetman Partition Recovery.
https://hetmanrecovery.com/recovery_news/how-to-recover-data-from-disk-encrypted-bitloker.htm
I have encrypted my local disk using bitlocker encryption and now it shows Local Disk(D:) is not accessible Access is denied and when i right click it was not showing security tab. please help me
Try This:
Before you start
  • You must be logged on as an administrator.
  • The volume must be encrypted.
To turn off BitLocker Drive Encryption
  1. Click Start, click Control Panel, click Security, and then click BitLocker Drive Encryption.
  2. From the BitLocker Drive Encryption page, find the volume on which you want BitLocker Drive Encryption turned off, and click Turn Off BitLocker Drive Encryption.
  3. From the What level of decryption do you want dialog box, click either Disable BitLocker Drive Encryption or Decrypt the volume as needed.
    By completing this procedure, you have either disabled BitLocker or decrypted the operating system volume.
    Good Luck!!
How can i take the bitlocker off my PNY 4GB flash drive?
Windows version like XP.
There are 5 steps to remove BitLocker Drive Encryption from removable drive. Here are the steps.
  1. Open Control Panel then click on BitLocker drive encryption link.
  1. On the nest window, click Turn Off BitLocker link on your removable drive or USB flash drive.
  1. Next, the BitLocker Drive Encryption window will appear, click on Decrypt Drive button to start the decryption process.
  1. The decryption progress takes some minutes to finish, so wait until the process completed. Do not plug off your removable drive during the process.
  2. After the process completed, a message box appears, tell you the decryption process was completed. Click on Close button to close the window.
right click on your 4 gb usb drive select turn of bit locker in W7
hope it helps you
1helpful
2answers
Need to remove bitlocker from USB2.0
hope it helps you
My pen doesen't work in my portable with vista but works in a computer with windows 7
Hello
Did you encrypt the USB memory drive while it was in the Windows 7 computer? This would prevent any other computer from seeing the USB drive.
Try using the drive on another comptuer - if the 3rd PC fails to read the drive, put it back in the Windows 7 computer and remove the data encryption from the drive.
The following link is from Microsoft TechNet and provides details on how to enable and disable BitLocker encryption from drives.
1helpful
Dell Media Direct Cannot access hard drive due to bitlocker encry
Sounds like the hard drive was encrypted prior to the upgrade to SP2.
If that's the case, you may have created a password during the encryption process. See this reference to recall the steps for encrypting a hard drive with Bitlocker.
If for some reason, you never encrypted the hard drive and do not have a password, then the encryption may have been caused by some bug in the upgrade and you should contact Microsoft to resolve.
What is the main difference between window XP and VISTA?
Windows Vista & Windows XP
1. Bitlocker Option available Windows XP has . No Bitlocker option
- Bitlocker drive encryption,
Bitlocker on volume
Prevents hard drive from hackers
2. Windows Vista has Windows Defender tool Windows XP has No Windows Defender tool available
- prevents from spyware & unwanted
S/W installing on computer
3. Windows Vista has Parental control Feature Windows XP has No Parental control Feature
- This option enables parents to restrict
Children’s which sites, games .software
to use & not
Top Lenovo Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
