Skyscan atomic wall clock 87315. Changed battery and cannot locate instructions to reset PST and temp. Is on correcct day and date but EST and seconds. Advice please. Fran
I have the same model. Make sure you have good batteries and move the clock away from any electrical equipment. Since WWVB broadcasts at a frequency of 60kHz, this could be a harmonic of 60 Hz.
If all else fails, remove the batteries, take the clock outside and reinstall the batteries. If you do this at night you should pick up a signal..
I just had to move my clock out of the computer room and it picked up the signal at noon.
Simple, the instructions state that when changing the batteries on the outside temp. sensor, you must also change the batteries on the main clock unit. I had same problem when I changed the sensor batteries until I pulled the batteries from the clock and it reset fine. ( Sensor batteries first, then clock batteries. ) The clock will reset to atomic time overnight so don't worry if it doesn't read correctly at first.
Just did this after problem resetting after changing batteries, press setover and again til it displays est, then press+until your time zone is displayed, it will also display dst, press +till on/or off depending on your location, then US will appear, clock will then set itself. Good luck, how frustrating.
