Cover the IR receaver on the tv, maybe something or someone is playing with it from outside or inside the house.
If that is not the case then there is most likely a hardware problem and you should take it to a professional.
Not much we can do to solve the problem if that is the case.
Hi, What is the model of your Television?
Here's some aspects that may result your TV not to Stop scanning the channels:
1. Check the antenna connection.
2. No IDs have been programmed.
3. The IDs you have stored are not active.
4. Check to see if many of the channels are Locked Out.
If so, the scanner has less chance of finding an active channel.
5. Review each channels frequency to see if it is still stored in Memory
and is correct.
6. Its possible that none of the programmed frequencies are currently
active.
Possible reasons why your TV set is auto channel rolling.
Try the menu key on your remote are you able to access the menu? Your tv may be in channel programing mode.
TV has a firmware issue. Firmware is the software that controls your TV.
Is there any buttons stuck? Take out the remote batteries and just try the TV.
Is the tv rolling over and over. Just let it go for 10 mins before you unplug it and see what happens.
If you push ch keys many times/ just push it for a long time it possible. Try to recall/rearrange from the system controls if not worked please visit service centre.
REMOTE DISABLED/BATTERIES OUT.SOUND GOES TO THE MAX.CHANNELS ROLL.CANT SHUT TV OFF.TOTALLY OUT OF CONTROL>HAVE TO UN PLUG SET TO SHUT DOWN>HAVE NOT LET IT RUN THIS WAY FOR 10MIN.
