My Hotpoint Aquarius CTD40 dryer keeps cutting out. Have checked & changed the fuse. Will start for about 2-3 mins then trips out at the main box. What is wrong??? Thank you. Jayne Burke
Check the mains lead for continuity! Thats making sure the lead to the dryer is not broke anywhere internally.
It may mean removing panel to get access to where the mains lead goes into the dryer, You can do this with power off, check with a multimeter that both the brown wire and blue wire as well as the green and yellow earth wire has continuity from the plug to the dryer!!
I would get an electrician to check the machine as it appears to have an earth fault on the machine wiring , This type of fault will operate the RCD quicker than the fuse will operate. I am a qualified electrician by trade.
hello, the reason for this because theres a dead short inside washer or the socket may have a loose wire check all the earth wires inside the washer and the sockets get back to me if you still have trouble
sounds like bearings in your ctd40
We have made a few videos on these dryers and there are some very good repair guides on these.
if you need parts please feel free to see site or contact me with the full model number of the ID plate How-to-Repair
How replace the bearing kit
And if you have the type with a fixed Riveted Drum shaft then you will need this video
In our repair guides you will find help on all the tumble dryer problems
Common faults - 1 Theheating elementscan fail(meaning open circuit) 2 There arecut-outs (T.O.C's)thatmight need resetting 3 Thethermostats (stats)can tripout or burn out (meaning opencircuit) 4 Moderntumble dryers also have sensors andpcb's (Printed circuitboards)thesehaveprograms that can fail and circuitry although most should produce an errorcodeshowing you were the fault is. 5 Faultyconnections and burned wires may also bethe fault.
You-Tube video "sfGInKA3yp8" placeholder (do not delete)
