SanDisk Cruzer Micro 4GB USB 2.0 Flash Drive Logo
Posted on Jan 31, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Just 1 week i worked., it showing the error when file transferring after 25% . ERROR: CANNOT FIND SPECIFIED FILE... so i formated os. but now again showing that same error. pls tell me what i've to do. help pls
Anonymous
Level 3:
  • Master 2,517 Answers
  • Posted on Jan 31, 2010
Anonymous
Master
Level 3:
Answers
2517
Questions
Helped
484073
Points
8373
Your flash drive is corrupted. Try from any other pc if you have got the same problem the visit your buying location and return that. You have 1 year warrenty so they will gives you new 1.
Thanks, i am waiting for your feed back & if you satisfied then thumps me please.
Anonymous
Level 2:
Scholar:
  • Expert 146 Answers
Anonymous
Expert
Level 2:
Scholar:
Answers
146
Questions
6
Helped
70863
Points
463
You need to format the Flash Drive not your OS.
3helpful
Audio error
Did you drag the video and audio files.
There is no reason to format a dvd-rw, if you want to use it again
just delete the files on the disk, if you format it, you could cause it to stop working or not accept files.
You format a hard drive to change format, or install a OS.
You don't use format on CD or DVD's just to erace them.
Nero also has an erase option.
tip
Play Tivo HD Videos on Motorola Droid X,TS Tivo to Droid X How to convert and...
How to convert and play TiVo shows on Motorola Droid X? To solve this problem, you need to transfer TiVo, TiVo HD shows to your PC and then convert them to Motorola Droid X MP4 format with Aunsoft Droid X Video Converter. With the recommended software, you can convert TiVo, TiVo HD, TS TiVo shows to Droid X mp4 by yourself fast and easily!
How to convert TiVo to Motorola Droid X MP4?
This guide includes 3 parts:
Parts 1: Transfer TiVo shows from TiVo DVR to PC
Parts 2: Convert TiVo to Motorola Droid X MP4.
Parts 3: Transfer converted TiVo shows to Droid X.
To transfer TiVo shows to PC, you need to download TiVo Desktop Software. When your TiVo is connected to your home network, TiVo Desktop provides you with a list of available shows for transferring to your PC.
After you transfer TiVo files to your PC, you can convert them to Droid X mp4 format. First of all, download TiVo to Droid X Converter and launch the application. Then follow the steps below:
Step 1: Import TiVo files to TiVo to Droid X Converter
Enter Media Access Key for your TiVo files from “Option” button and then load TiVo files to the TiVo to Droid X Converter.
Step 2: Edit TiVo files
Editing functions are available by clicking “Editor” button in the menu bar. You can crop, trim, add text/image/video watermarks, replace audio, add special effects, etc. you can check “Apply to all” to apply the present settings to all the TiVo files.
Step 3: Choose Motorola Droid X MP4 output format
After you finished editing, you then choose output format from “Format” drop-down list and specify the format Motorola Droid X H.264 Video (*.mp4) (recommended) under Android profile among the options.
Tip: The default resolution of output format H.264 MP4 is 480*320, if you don't like it, please click "Settings" to set the size (pixel) to 800*480 or 854*480, or you can custom the resolution if you wish to.
Step 4: Convert TiVo shows to Droid X MP4
Click “Convert” button to start converting TiVo to Droid X MP4. Check “Merge into one file” to join all TiVo files to one output Droid X mp4 file before start conversion.
After converting your TiVo shows to Droid X, you will get mp4 file(s) in destination folder. Then you can transfer your videos to Droid X for playing, if you have any problem on transferring files. Please read: Transfer or Copy Movies and Musics to Motorola Droid X.
Now you are free to enjoy your TiVo recordings on Droid X wherever you go.
on Aug 04, 2010 • Cell Phones
Unable to transfer files to sony 4gb pen drive
Restart your PC and try it again or try it on other PCs. If problem persists then pen drive is defective. Return to retailer and ask for a replacement.
Cannot transfer files in to sony 4gb pen drive
try a different usb slot ..if that doesnt works then it sounds like your pen drive is damaged .. that can happen in several ways .. if you carry it around with you, make sure the cap is on ... it can get static zapped otherwise .. also the gold fingers inside can get dirty .. another way the drives are damaged is to remove them while data is still being written to the drive ... wait until the light is no longer flashing before removing .. if you are using win98 or winMe .. then make sure you turn off the device before removing ..
2answers
Pen drive is not able to write any data
How are you formatting it? NTFS or FA32?
I suggest you reformat as FAT32
When im viewing the photos ive taken i get a 'file error' on the screen......why?
I need more information in order to help you.
What software are you using, and where are the pictures located? If you have not yet transferred them to your computer, the application may not be able to access them fast enough, and could result in this error.
Transfer first, try again from the local drive.
If that does not work, please include additional information including the software in use, location of images, file formats, and platform and OS you are on (PC, Mac, etc.).
3helpful
3answers
Sony NW-E405 MP3 Player
Try formatting the device again using its built-in formatting features.
(WARNING: There is no way you can retrieve your data. Since it has already been formatted, it's assumed that you have backup.)
In your Sony NW-E405 MP3 Player:
1. Press and hold the SEARCH/ MENU button
2. Go to ADVANCED MENU (press the Play/ Stop button)
3. Select FORMAT (press Play/ Stop button)
4. From the opt "Format OK?" select OK (press the Play/ Stop button)
5. Once finished, you can Cancel out.
After these steps, your device should screen out "No Data." From there, you can re-transfer your files.
1helpful
Help retrieving files from simpletech 320gb hard drive!
I have to admit I haven't used a Mac since high-school, but I can tell you that my first thought on this problem was "file system".
Most external HD's are formatted to be used on a Windows PC, and many are even formatted as NTFS. If this is the case, last I heard anyways, Mac OS doesn't support NTFS.
My suggestion is to use either machine to format the external HD (**you will lose all data on it**) as a neutral file system. By that I mean one which will work on both operating systems.
I could be wrong about this, and Mac OS may support NTFS, but if that's the case somone will be kind enough to correct me.
1helpful
4answers
File format error - Transcend T.sonic 610(1gb)
I had the same problem. I had formatted the player's drive using Windows explorer and the got this error: "File Format error" while trying to play any mp3 file.
I went to the command prompt. Deleted all files:
E:\> del *
Then I copied the MP3 files again in the T.sonic MP3 player. All MP3 files played fine after this.
5helpful
5answers
Snoy NW-E105
I Think The Problem Is That Your Formatted your Mp3 Player Through Your Pc That Is What Created The Format Error You Need To Format Through The Menu Of Your Mp3 Player Directly You Might Have To Do It Twice And it should Work Well
Top SanDisk Electronics - Others Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
