I have had the Whirlpool 4.0 Cu. Ft. high efficiency front-load washer for about 2 years and within the last week or so it has started to make an obnoxiously loud noise during the spin cycle. The noise is only during the spin cycle.
It's a clunking kind of noise. I adjusted the front feet settings downward and it helped lower the clunking noise a little bit but now is vibrating a little more.
with a clunking noise is that from one of the springs breaking?It's a clunking kind of noise. I adjusted the front feet settings downward and it helped lower the clunking noise a little bit but now is vibrating a little more.
AnonymousMar 15, 2014
what is d5 on Samsung - 4.0 Cu. Ft. 15-Cycle High-Efficiency Steam Front-Loading Washerwhat is d5 on Samsung - 4.0 Cu. Ft. 15-Cycle High-Efficiency Steam Front-Loading Washer
AnonymousMar 30, 2014
The spin cycle on my high efficiency washer will not workThe spin cycle on my high efficiency washer will not work
You can't post conmments that contain an email address.
What kinda noise, sqeeling, or clunking, mite be sumthing small that made its way behind ajatator an is causeing noise..or one of the springs that hold it broke..sorry i dont no what kind of noise.....
Top Loader? That sounds like a gearbox problem. It is not an easy fix. With that much use and those many years, it is probably time for a new one. A new High Efficiency Front Loader, will save you a fortune in water, electricity and detergent.
Try this forum though if you want to try and get it fixed.
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
The loud noises seem to be a feature of newer front loading machines. We bought a Maytag and have had similar issues since day 1. We were told the bearings are the problem. They don't last and make major noise as they wear.
i just had my washer do this to me last weekend. In the final spin out it made a loud noise and i noticed that the plastic between the metal tub and the outer plastic tub was rubbing away.I'm going to tear into it my self being that its out of warranty. Mine is about 6 years old too.
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
i would try removing the lower acess panel(2 5/16 screws . from there you should be able to see where the "ticjing" noise is coming from, likely source is cracks in belt assy
