1st Option: Go to BIOS level and select the CD/DVD device is the first device for boot option and then insert the recovery CD/DVD to format or install OS.
2nd Option: If recovery CD/DVD got curropted and you are having the other OS CD/DVD, then try to load and format or install the OS. Also try to download the recovery image from vendor website.
Revert back for more assistance.
Sorry for the delay....Insert the restoration cd which is came along with computer and format the HDD.
Also have tried the 2nd option? if not try and update me.
If your recivery CD is not working properly, then need to download the recovery image from the vendor website or contact the vendor for recovery CD.
You are absolutely right..Biostar is the motherboard manufacturer's logo when the initial boot up you will get this.
One more thing i want to know is whether the HDD is detected in the BIOS level.
Still i have not got any update from you. If your problem got resolved, Please give your valuable feedback/rating on the same.
Plug it to a working computer as a slave.
go to disk management
then format the hard drive.
here are links that you need
http://support.microsoft.com/kb/309000
http://www.bleepingcomputer.com/tutorials/tutorial116.html
Look inside your windows, Click the Start button and then select "All Programs" and then "Accessories" and then "System Tools" and finally select "Backup" Your computer has a recovery partition from which to perform a complete system recovery. You will need three blank CD-R discs to complete your backup. You can also order the original restore CD from emachines (owned by Acer) if your are scratched up or damaged.
When you first start the computer with a new drive, you must boot the computer with the software that came with the hard drive. This software has the drivers for the hard drive and most importantly, it has the utility to "Initialize" the drive and then format and partition it. Once the drive is "Initialized", then the restore discs can be used.
have gone into bios and made sure boot from is on cd. computer has two cd drives, have tried both. get further with one than the other but niether will start the install process.
emachine T2778. have made sure bios is set to cd. neither cd/dvd drives will start the install process.
no software came with the new hard drive. the only disc I have are the three restore disc that came with the computer.
the recovery disc are not working. The bios is set for boot from cd but it will only go so far and then doesn't install os.
When the computer is started without a disc in the drive, Biostar logo comes up on the monitor, which I'm guessing is the motherboard that is in the computer.
