My signal has been very weak lately on my nokia 6300. Whilst making a call, the connection dropped and I decided to power off the phone and power on again. The battery was pretty full but the phone just wouldnt power on again. If I keep the power button held down there's a small blue flash from the side lights. I tried charging the battery again and I go the small battery sign showing its charging but the phone still wont power on.
Please help.
Shabs
Thanks for that tip.
I had a look at the BSI pin. It did look like it was positioned slightly farther back from the others and I tried pulling it out gently with no luck. I can see though that the pins are sprung so I'm sure its definately coming into contact with the battery connectors.
The other thing is that with the Nokia 6300, I'm told you can turn it on without the battery if plugged in to the mains charger. I tried that but it still doesn't power up.
When I stick the battery in and try charging the battery from the mains, I get the usual battery indicator showing that its charging - but again, no power on, just a flicker of the blue side light.
Any other suggestions?
Thanks again
Shabs
yea i have same probs mate fine one min and dead the next i need to get my phone nos out if it wasen 4 that you can fix the problem bye havin the phone flashed any suggestions 4 me please any one just leave soloution thanks
mine does not power on at all after it fell from a balcony fixed my screen but still the fone does not power on.
I've charged, taken battery out, used power button with down volume and it still wont turn on
