2004 Dodge Stratus Logo
Posted on Jan 30, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Very loud sqeal upon driving and movement upon turning the wheels, noise only coming from passenger front side of a 2004 stratus
steve morris
Level 3:
  • Dodge Master 1,675 Answers
  • Posted on Jan 30, 2010
steve morris
Dodge Master
Level 3:
Answers
1675
Questions
0
Helped
653607
Points
5484
Sounds like the power steering pump bearings might be u/s does this happen when you are stationary as well??
Anonymous
Level 2:
New Friend:
  • Expert 105 Answers
Anonymous
Expert
Level 2:
New Friend:
Answers
105
Questions
0
Helped
32636
Points
250
Sounds like powersteering pump,or rack and pinion,check fluid level
Loud grinding/clunking noise when driving, lessens when I press the brake
Loud Noise Unknown Origin - Ask the GM Technician - GM-Trucks.com
www.gm-trucks.com > ... > Ask the GM Technician
Jun 30, 2006 - 7 posts - ‎3 authors
I get a loud clunking, grinding noise while turning to the right only, and ... I moved the passenger side tire to the rear driver side just in case it ...
can bad wheel bearing/hub cause loud clunking noises?
www.jeepsunlimited.com/.../showthread.php?...loud-clunking-noises
Nov 12, 2009 - 14 posts - ‎6 authors
driving home, i noticed some metal clunking sounds coming from the front driversside. at ... hmmmm....if it's grinding, then probably a bearing.
Front Clunking sound when driving straight. - TDIClub Forums
forums.tdiclub.com > ... > VW MKIII-A3/B4 TDIs
Dec 21, 2011 - I have a sporadic clunking noise from the drivers side front end. '98 jetta ... If I try to coast it gets really louder and more pronounced. ... whirring orgrinding could be several things: wheel bearing, brake pads due to a caliper ...
Quick Guide to Diagnosing Differential & Driveline Noises ...
2answers
Loud noise when turning the Wheel on front passenger side of 2004 Pontiac grand am
check for failed wheel bearings
check for worn pads and faulty disc rotor
if front wheel drive -check for failed cv joints
When driving a loud humming sounds almost like a tire is rubbing
Hello: Raise up the side (front or rear) the noise is coming from roll the wheel and wiggle from side to side. Any movement and or noise would indicate a failed wheel bearing.
3helpful
3answers
My car makes a bad growling noise. Everyone said that it was a front wheel bearing because that tire was worn down really bad on the outside. I replaced the passenger front wheel bearing, and it is still...
WHEEL BEARING USUALLY STARTS MAKING A ROARING TYPE NOISE WHICH USUALLY GETS LOUDER THE FASTER YOU DRIVE, SOMETIMES THEY WILL BE LOOSE , TO CHECK JACK UP THAT WHEEL AND GRAB TOP AND BOTTOM OF TIRE AND SHAKE, IF THERE IS MOVEMENT, TRY TO GET SOMEONE TO ROCK TIRE FOR YPU AND WATCH WHERE AXLE GOES INTO CENTER OF BEARING AND SEE IF AXLE IS MOVING WITH TIRE MOVEMENT AND SPINDLE REMAINS STATIONARY, THEN IT IS BAD BEARING, OR SOMETIMES THERE WILL BE NO MOVEMENT, THEN BLOCK REAR WHEELS AND RUN CAR WITH THAT WHEEL IN AIR AND SEE IF YOU HEAR NOISE, GOOD LUCK.
2helpful
2000 Stratus, 2.4 automatic. A loud humming noise
hi this sounds like you have a wheel bearing that has gone u/s the way to find out which one is to individually jack each wheel up and spin the wheel first you might hear a grinding noise, if not you can pull the bottom of the wheel and push the top in a rocking motion top to bottom, left to right if you get a large amount of movement then this will also point out which wheel it is....hope that helps
Whining noise from front end while driving
you have a bad front wheel bearing..jack up front of vehicle..put in neutral..block rear wheels..put 1 hand on front coil spring and rotate wheel..you will feel roughness in spring on side that wheel bearing is bad
1helpful
3answers
Loud roaring noise in front of dodge stratus ES 2000
i have a 2000 doge straus and i put two sensors in and it still wont shift any ideas out ther it was fine when parked a year ago so i know the tranaxle is good
2helpful
Very loud "rubbing " sound when driving only
you did damage to the wheel bearing i bet it sounds like a airplane sound. also if you steering wheel is off 7"then have front end aligned because this will destroy the tires and they will make noise.
Top Dodge Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Dodge Expert? Answer questions, earn points and help others
