2002 Volkswagen Jetta TDI Logo
Anonymous Posted on Jan 30, 2010
How do i replace my VW SHARAN 02 glow plug relay. and what is it. i have been told that the glow plug relay is going. Could you please tell me what a glow plug relay is and what it does??? Also do i need to replace the glow plugs as well.
steve morris
Level 3:
  • Volkswagen Master 1,675 Answers
  • Posted on Jan 30, 2010
steve morris
Volkswagen Master
Level 3:
Answers
1675
Questions
0
Helped
653475
Points
5484
The glow plug relay is a little black box normally located in the fues box, the relay regulates power to the glow plugs, if the relay is not functioning correctly the plugs will not heat enough or, you will have to allow a longer time to let them heat up, it acts like a switch as such, when you turn on your ignition it switches over to make a contact inside, which inturn starts the heating prosess of the glow plugs when they are at the correct tempreture or the onbored computer detects they are it then switches back , without it , say just using a fuse instead, your glowplugs will just get hotter and hotter till they melted, and no you dont have to change the glow plugs hope this helps, ime not good at explaining stuff in writing lol
Testimonial: "Good advice, I understand the concept of what i need to replace, now i can sort the problem out myself. CHEERZ u guys save us ppl money and time. "
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 08, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
2612
Points
Bulb indicator on dashboard panel are illuminated and glow plug indicator is flashing... I have no brake lights! anybody know what this is plse.
Vw sharan w reg turns over and sometimes fires but then dies, now wont start at all.
Just some info could be filter or fuel pump. copy and paste to google search. diesel which is takes some time to crank.
https://www.youtube.com/watch?v=yRMTEAKsScE
3helpful
Hi i have a VW SHARAN 02, glow plug light...
your glow plug relay is going out you need to replace it.
Glow plug light flashing on VW Sharan
i dont think it will hurt it, you might just be dealing with a loose wire
Can anyone tell me where to find the glowplug relay, it's a 7 prong relay, on a 2002 vw beetle 1.9 diesel no turbo ? allready been under the dash and checked all the relays, none of which are 7 prong,...
Above the Relay Panel is the Auxiliary Relay Panel. Has thirteen positions in it.
6 across the top, 7 across the bottom.
Across the bottom the Glow Plug Relay is the fourth one over from the left. It is Number 10.
(180)
02 VW Jetta TDI with ALH engine glow plug
this is a common problem for these cars glow plugs go bad like spark plugs however the smoke would lead to bad mass airflow meter. it is not telling ecu corrcet miss. disconnect mass airflow meter. when cold see if this makes it start better. it should would means you need new m.a.f. glow plug issue take a test light place clamp on positive of battery then pull off glow plug connectors place tip of test light on glow plug the bad one will have a dull light unlike the good one which will be brighter. will need new plugs and wire harness four **** connectors and wire striper and crimper will fix concern good luck
2helpful
2answers
The glow plug light flashes while the engine is
this means you most likely have a burnt out glow plug or glow plug timer control or both
VW Sharan 1997
Depending where you live if the temp. is over 45 degrees F the glow plugs shouldn't be needed for the engine to start. Have you ever had the check engine light come on? Your problem is probably not in the glow plugs.
Engine Maintainance light on
This could most likely be one of 2 things, 1. if it is your maintainance light, it is probably one of your sensors, possibly the mass air filter sensor, oil pressure sensor, and 2. If it is a diesel engine and its the glow plug light, you would need to replace your glow plug relay because it telling you that the glow plugs are still on when the engine is running, which you should take care of asap before you have to replace the glow plugs themselves.
Top Volkswagen Experts
ZJ Limited
ZJ Limited
Bradley
Bradley
Thomas Perkins
Thomas Perkins
Are you a Volkswagen Expert? Answer questions, earn points and help others
