Archos Internet Media Tablet MP3 Player Logo
Posted on Jan 30, 2010
How do i change battery in an archos 7 - Archos Internet Media Tablet MP3 Player
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Jul 04, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
507
Points
I have a archos 7 can you tell how I can change the battery
tip
Watch various videos and unprotected DVDs on ARCHOS 7
The ARCHOS 7 offers customer uncompromised access to the Internet, TV and media content… With its stunning 7 inches amazingly high-resolution screen, 800x480 pixels, and huge disk capacity, it is the best travel company and portable audio/video player you can imagine, which will definitely accompany your travels and holidays in a comfortable and convenient way.
To enjoy videos on ARCHOS 7, you should make sure what file formats are compatible with it, following is the detailed information:
Video playback:
MPEG-4 (ASP@L5 AVI, up to DVD resolution)
WMV (MP@ML, up to DVD resolution) including WMV protected files
M-JPEG (Motion JPEG Video) in QVGA resolution
With optional plug-in (downloadable from your tablet on www.ARCHOS.com):
HD support: MPEG-4 (ASP 720p) & WMV HD (MP 720p)
H.264 up to DVD resolution with AAC
MPEG-2 MP@ML up to 10 Mbps (up to DVD resolution) and AC3 stereo sound (5.1)
Audio playback:
Stereo MP3 decoding @ 30-320 Kbits/s CBR & VBR, WMA, Protected WMA, WMA pro 5.1, WAV (PCM/ADPCM)
AC3 stereo audio and 5.1 sound files (via SPDIF output of DVR Station)
Flac and OGG Vorbis audio files
With optional software plug-ins (downloadable from your tablet on www.ARCHOS.com):
AAC, AAC+ stereo audio files
Obviously, the ARCHOS 7 supported file formats are limited, if you want to watch you various video files and unprotected DVDs on it successfully, format conversion is necessary. By now, Pavtube Video Converter would be a good assistant for you. It is able to help you convert videos from DVs or camcorders (JVC, Panasonic, Cannon, Sony, etc.), TiVo (*.tivo), DVDs (*.vob), YouTube (*.flv, *.f4v), *.mts, *.m2ts, *.mkv, etc. to ARCHOS 7 compatible format. You can look through its step by step guide as below.
Step 1: Run Pavtube Video Converter, and click "Add" button to load video files to it
Step 2: Select output format for ARCHOS 7
Click on the pull down menu of "Format" firstly, and then select "Archos", after that, all the profiles for Archos will be listed out, here I choose "Archos 5/7 WMV Video (*.wmv) for example.
Step 3: Specify destination folder
Click on the folder icon at the end of "Output" to specify where to locate the output files.
Step 4: Click on "Settings" button to adjust audio and video parameters
Actually, the default settings can basically satisfy your ARCHOS 7, but if you want to have your own changes, you can adjust all the items like codec, aspect ratio, frame rate, sample rate, bit rate, and audio channel in the following window:
Step 5: Click "Convert" button to start conversion
Once conversion is finished, the output files can be found out via clicking on "Open" button with ease. Afterwards, just enjoy them on your ARCHOS 7 freely.
For more: http://www.pavtube.com/video_converter/
on Feb 23, 2010 • Televison & Video
2helpful
How do you change the battery on an archos 7 320gb
The ARCHOS 7 has a removable battery. You can purchase extra batteries fromwww.archos.com.Caution: if the battery is incorrectly replaced or short-circuited, this could resultin damage to the product and/or serious injuries to the user. Replace onlywith an original Archos battery.To replace the battery, follow these steps:
MY NEW ARCHOS 7 INTERNET TABLET AFTER CHARGING CORRECTLY THE FIRST TIME WILL NOT CHARGE ANY MORE
Get in contact with Archos. Let them know you need to RMA the device due to a bad battery cell.
My archos 7 light is only red and won't turn on
Try Removing the Battery for about 30 seconds then plug it back in
2helpful
How to change Archos XS202 battery?
Hi !
I found this site which sells batteries for archos xs202 :
http://www.newmp3technology.com/xs200+batteries.html
Then you have to remove the covers (back and front) of your archos. Then melt the tin that retains the battery cables with a soldering iron.
Then melt the tin again to fix the new battery cables to the motherboard and you're all set. I did it this very morning without problems.
1helpful
Archos 5 60gb won't charge
How old is your unit? Maybe your battery is dead The one good thing about having a Archos 7 is that you can change the battery easily. Have you backed up everything on your archos? I hate to say it but you might want to try repair , recovery or your last gasp format the unit.
Try using the tools/settings/customer assistance function first. I have not had good luck with tough problems using that function, you might have to do a hard reset.
My archos 7 wont charge the red light comes on but wont charge tried resetting batery no use put a new battery in green light came on looked like charging but didnt in the end
If the archos was purchased new from Archos stores they have warranty on them call tech support to find out. Have your serial number and product model number handy.
Top Archos Audio Players & Recorders Experts
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
