SOURCE: i need to know how to convert it to a toddler bed
The front rail just comes off and then the toddler is able to get in and out.
We did this with ours and it worked out great.
SOURCE: converting crib into toddler bed
Call customer support @ 18002951980 and customer support can either email or fax instructions at no charge. I just did it and got the instructions myself. Or you can email me @ [email protected] and I'll foward the instructions to you.
SOURCE: convert crib to toddler bed
I finally found my instructions!! It's actually really easy to convert to a toddler bed:
Step one: Take out four screws (two on each side) of the front railing and top bar. They are the screws holding the front railing and the top bar to the side of the crib and the dresser.
Step two: Lower the mattress to the lowest setting.
Step three: Place the toddler bed railing in place. It can go either way depending on which side of the crib your toddler sleeps. We put the taller part of the toddler railing closest to the dresser because that is where our son's head usually is.
Step four: You'll need 4 1.5 inch hexagonal screws to screw in the toddler railing. After 2.5 years, I could only find two of them, so I used two 1.5 inch regular screws that came with the crib. On the taller part of the toddler railing -- the screws go into the 1st and the fifth holes. On the shorter side of the railing, the screws go into the 3rd and the 5th holes.
That's it.. You've now got a toddler bed!
SOURCE: Need instructions converting crib to toddler bed
I have all the instructions posted in an album on photobucket.com. In the site only search field (not the web search) type emilykenepp and change the search criteria from images to people. This should bring you to my profile- under my albums I have an album titled Graco Lauren Crib Assembly Instructions. Click on that and you should be good to go! Pages 10 and 11 are for the conversions. Also, for any further assistance, the customer service number for LaJobi (the people who actually manufacture the crib for Graco) is 1-888-266-2848 and for Graco it's 1-800-345-4109. Hope this helps!
SOURCE: graco lauren crib conversion instructions
I have posted the instructions in an album on photobucket. I believe you can print them from there. To get to them, go to photobucket.com and in the website only search field (not the web search) type emilykenepp and change the search from images to people. It should bring up my profile and under albums I have an album called Graco Lauren Crib Assembly Instructions. Click on that and you're good to go! Pages 10 and 11 are for conversions. If you have any further need, the number for LaJobi is 1-888-266-2848 and the number for Graco is 1-800-345-4109.
