Surging is generally caused by carburetor problems. Squirt some carb cleaner in it and see if that helps it at all. If that helps but does not do a lot, then the carb probably needs to be rebuilt. The carb could also just need some adjusting. Check for fuel leaks around the carb and also be sure the air filter is clean. Good luck.
Hope this helps. If it does, I'd appreciate your vote. Thanks,
First make sure you have fresh gas in the tank, as old gas can cause a 'no run' condition. Once you have fresh gas in the tank, make sure the gas flows freely all the way to the carb by removing the fuel hose from the carb inlet & checking for good flow (bad shut-off valve or obstructed hose by debris could cause same problem). Once you are sure that good, fresh gas is going into the carb w/o obstruction, remove the lower bowl from the carb - carefully - do not lose ANY parts, starting with the washer on the bolt. With fuel flow 'ON', fuel should flow freely when this bowl is removed, so shut off fuel valve in the hose. Now, if you carefully remove the bolt / brass tube from the center of this bowl area (center of plastic float) - remove bolt downward, like you would a lightbulb from the ceiling - this bolt should have several holes in the side, they are probably clogged, so unclog them with a needle or wire, wipe clean, and reinstall. That probably just solved all your problem.... if not, you likely will want to replace the carb completely, as it is not very expensive, and will surely solve your problem. *** Be careful with gas fumes !!! ***
Yes, you can use a welder with it. Pay attention to the ratings of the welder, don't exceed running watts of the generator. It would also be a good idea to try and use a welder that is less than the running watts rating of the generator. Then you would have some extra capacity to deal with fuel quality, maintenance history, momentary undervoltage, altitude, etc.
Make an Umbilical recepticle adapter. Buy the recepticle install the recepticle in a 4" electrical BOX on a plate with two manufactured 3 prong power cords plugging into the 2 outlets and terminating at the new Box twist lock recepticle you made.
Check the fuel filter. My company designed hybrid generators that are far more efficient. They use batteries to power your equipment, and the generator runs intermittantly to recharge the batteries when needed.
If you would like to convert to hybrid, contact me at [email protected]
