The bendy chrome pipe which water goes through to refill the cistern after flushing started to leak a little a couple of months ago and water eventually found its way through the boxed in tiling at floor level. The toilet was loosened and pulled forward to allow a new chrome pipe fitting to be attached.This was a longer version of the pipe to make it easier to slide the toilet back into place.
Last night noticed water again at floor level and when I looked inside the cavity where the feed pipes are could see water has leaked again.The chrome fitting is as far as I can see still attached and the loo is flushing as usual.I am assuming this fitting is working its way loose and creating the problem allowing water to escape.I dont understand why this should be? Any comments or suggestions most welcome.Thanks.The product is Duravit starck 3 close coupled toilet
SOURCE: cannot remove top of cistern
There are some dual flush cisterns where you have to depress one button to reveal a cavity in the second button. Put a screwdriver in that cavity to lever out the second button, then release the first button and prise that out.
Underneath the buttons is a screw which must be unscrewed to release the cistern lid.
Not sure if this will apply to you... but if not, good luck anyway.
SOURCE: Have a Duravit Starck 3
Unfortunately you won't find a universal replacement part to work with this seat which you would commonly find at your local hardware store. I've looked through the Durovit site and could not find a parts catalog. Try using the find retailer option on the manufacturers site and if there isn't a retailer in your area contact the manufacturer directly to see if they supply parts for their seats. I'm guessing they don't and you would likely have to purchase a new seat.
http://www.duravit.com/service/find-a-retailer-useo6suuk8.html
Duravit USA, Inc.
2205 Northmont Parkway
Suite 200
Duluth, GA 30096
Phone +1 770 931 3575
Toll free: 888 387 2848
Fax +1 770 931 8454
Toll free: 888 387 2843
[email protected]
SOURCE: I removed the lid from my Duravit cistern. I
the botton should adjust up and down by tuning it left or right
