Trying to install windows 7. said I needed service pack 1. downloaded it. retried to install windows 7. got same pop up. How can I install windows 7?
Are you installing within Windows? If so reboot your system with the Windows 7 system disc inside your cd rom, you should see message that says Press Any Key To Boot From CD at this point press any key. The system will load the installation files the it will ask you if you want to install or perform recovery you will select install, then it will ask you if you want to format your hard drive. Formatting your hard drive will erase the entire drive so back up any desired files. This will successfully install windows 7.
Install windows 7
qb 2066 small business install on Windows 7, How
