Iv got the same problem too, iv resync it and nothing, wiped the wii clean and started again and nothing (mine went down just b 4 xmas and 'santa' got my boy the wii fit plus and he ant been able 2 play it yep) PLEASE PLEASE PLEASE some1 help
It is not a problem with syncing. It has to do with one of the corner sensors. I have repaired many in the past with this problem and 98% of the time, the screw inside of the board on the foot closest to the orange and white stick was too tight causing the sensor to always be on. The other 2% is most likely some damage with the circuit board which would require a repair from Nintendo.
The Repair:
with the board on and synced, go to the training menu and enter the part of the game where it tells you to step off and press A. Flip the board over and with a phillips head screw driver, unscrew the three screws around the foot I mentioned above. Remove the pieces and you will find a large Torx T30 bit under that holds a metal plate to the top of the sensor block. If you don't have that, a Flat head screw driver that fits in the slot will work. Slightly loosen that screw. Just enough so that its a little looser but not too much because it will cause that side not to function at 100%. After doing this attach the foot and plastic piece and screw the three screws in most of the way. Flip over and press A and the system should go past the error. IF not repeat the steps with little adjustments until the problem is resolved.
Thanks Mike, 2 min job, your a star xxxxxxxxxxx
Thank you Mike. I had to tweak all 4 a few times but now good as new. You are a genius!
Mike757 - I read your post and gave that foot an ever so slight turn. Good as new. Great advice, thanks
My wii balance board keeps saying to step off and press A...i do this a pressing and it doesn't work i came accross this little page and i tried to re sync it but nothing has changed.....what next
You need to re sync the wii fit board.
SOURCE: I have finished setting upthe
It seems your Wii sensors are stuck, This is a hardware problem which requires you to open up the scale and should really be done so by a representative of Nintendo. Unless you know what you are doing, call up Nintendo or return it to the store and get another one.
