RTO PasLode 900420 Impulse Framing Nailer  Logo
Anonymous Posted on Jan 29, 2010
Gun will not fire, battery is charged & good ??? model #IM25011 part # 900400 Bob
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 30, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
770
Points
Problem solved - battery charger indicated that battery was charged with green light on, took battery ouit & placed it back in charger & red light came on after doing this three times the battery was fully charged and the gun worked fine.
thanksBob
I have a bostitch farming nail gun the red light is continues the battery is charged but gun will not fire
Could be the mechanism is stuck or if the battery is not new could read fully charged but only partly charged.
2answers
Need two firing pin springs for Berrtta model 418 Batham .25 auto
they are $15 at bobs gun shop. you may have a local gun shop that can get parts. here is link
All Available BERETTA FACTORY GUN PARTS Bob Gun Shop Beretta Factory Gun...
scroll down an see parts
Jul 26, 2017 • Optics
Paslode 350i first fix nail gun. Charge both batteries (1 is brand new). Put battery into gun and fire. Im lucky to get one nail from it before gun shows up red.
Sounds like either the battery is bad, or since one is new its possible the contacts in the gun are not making proper contact. Are you sure your charger is working as well ? If you have a volt meter check that the battery does have a charge on it.
I am trying to find the model number and the value of a S&W 32 hammerless revolver
If you write to Guns & Ammo magazine they will answer you. they have a column monthly about gun values.
I have a paslode airless framer that wont fire. New batterry & fuel cell. It make the noise but wont fire
Hello harderconstr, I have that nail gun myself, and when it's working good it is a great tool to have.
Here are a few suggestions.
1. Remove the battery, make sure that you don't have a nail jammed in the the firing chamber, that has happened to mine before.
2. Adjust the depth tension on the end of the gun. You should have an alen wrench to loosen the adjuster at the tip. Slide the adjuster away from the gun, ( out ) as far as it will go and then tighten it back down. Reinstall the battery and try it again. You can re-adjust the tension after you see if this helps the problem. The adjuster on my gun was worn and I needed to adjust the tension to get it firing again.
3. I also got a new battery for my gun, and what I found was I really had to slide the battery in pretty hard to get it to click in place. Also, when you hold the gun in your right hand, the thumb side of the handle should have a very small LED light, red means it's not ready to fire, green means it is ready to fire. Make sure you have a green light.
I hope this helps you my friend!
Fires 2 & 3 nails every so often.
Most all nail guns can be converted to single fire, however, usually parts must be changed. Some brands have two positions on the trigger, others have a button position near the trigger to accomplish same. Check with dealer or email your gun model # and I will explain your to fix. For now you can replace the spring on the safety with one slightly stiffer. Also try nailing with trigger depressed and quickly bump the gun to fire, this method usually works better than placing the gun in position then firing. Good luck with your repair.
2helpful
Paslode nail gun 325 black not firing
Any time these guns become intermittent or stop firing but the fan still runs, the first the to check is the expiration date on the gas cartridges. The do expire and this will make the gun work inconsistently or not at all.
1helpful
Gun wont fire
First do a check:
The battery is good and charged
The co2 tank is not empty
make sure the gun is not jammed
try moving the guide on the top front of the gun forward
Hope this works but not for sure with out further explaination of what is wrong with more detail.
1helpful
2answers
Hitachi Framing Gun Not Firing - Bad Battery?
Does the fan run and the light blink ont he nailer? I have one that I just bought. I put in the wrong type of nails and got one stuck. I had to take the front apart to clear it and now the damm thing wont fire. The green light blinks and the gas cartridge is basically full, even the fan does run after I release the push lever, but no fire???
I wonder if yours is the same as mine did fire for a couple nails first just fine then got jammed...
I will try to charge the battery more.... MAybe like yours it needs a strong charge for the spark...
Russ
Top RTO Air Tools & Compressors Experts
Are you a RTO Air Tool and Compressor Expert? Answer questions, earn points and help others
