My sirius satellite radio stopped working antenae not found
My sirius satellite radio stopped working the screen states antenae not found in the car and at home on the boom box the antenae has been checked and is not the problem can this be fixed ?
Re: my sirius satellite radio stopped working antenae not...
Sirius Satellite RadioThe XM SkyDock incorporates an XM Satellite Radio Tun- er . A special .... image to match the XM SkyDock's .... found on the My Account screen (in Settings), ... Button: Tap to tag the current song and add it to your tagged song list . For.
IF you have a long rear window, and free of the rear window defogger lines, you can sometimes get by with the SAT antenna all the way to the back window INSIDE the car - if you have local satellite repeaters, it will work halfway decent; without local repeaters, it might be spotty.
I am having the same problem. Sirius must've sent out a bug cause many stiletto users are coming forth. Mine stopped working about 1 month ago as of today March 26. Sirius Representative told me today that they are being discontinued.
My AVIC-F900BT was stuck on one channel and wouldn't change. There was no sound. Radio head detected Satelitte system, but no buttons worked. Found on the internet a solution that worked for me. I disconnnect the battery terminals for 5 minutes and then connected them. When the system rebooted, the Sirius radio worked fine. I'm posting this hopeing it will help someone.
What you'll actually need in order to get Sirius is a satellite specific receiver (the JBL SIR 2.5 Satellite Receiver). That should come with the antenna you need.
Make sure the antenna has a good line of sight. Sirus works best when pointed in an Easterly direction. By default you should get channel 184 if there is no service activated on the radio.
All Sirius radios can be used for service only in the United States and Canada.
If you feel that the line of sight is ok and there are no obstructions from pointing your antenna either out of a window, on top of the car, or outside if it is used in a house, then try a different antenna. If you are using the smaller guage antenna wire, the connections can break inside during installation in a car from time to time.
If the radio is factory installed contact sirius at 1-888-539-7474 to see if they can see the radio on their end.
