Its the bottom right, what do i do. I heared it's my software ,but i think it's easier than that (I Hope). Help
The cause of E-74 with one red light problem might be overheating of your console and for
avoiding such error in future you need to put your machine at an open
space. Ensure that it is placed near the window or you can also make
some external arrangement for cooling of console such as cooling the
machine through a pedestal fan.
But as your Xbox already have E74 with one red light Problem which can be solved by only repairing it, no other alternative.
Either
you can send your Xbox to Microsoft (Please note that microsoft is no
longer providing extended warranty for E74 with one red light Error) and wait for 3-4
weeks. If you don't want to wait for a month, you can also fix E74 with one red light
problem with the help of this DIY Video, the guide will explain step by step approach to fix the problem. Choice is yours.
It could be a few things. I would recommend calling Microsoft Tech Support on this one. Some causes of this error code are:
Section 4 is flashing red
- Hardware Failure
The Specific Type of hardware failure can be determined by the error code displayed on the screen.
If
the screen is blank or you would like additional information follow the
instructions for determining the secondary error code in the section
below
E45: Unknown (possibly dashboard update related)
E64: DVD Drive Error.... DVD Timeout, Wrong firmware, dvd is without f/w chip, etc.
E65:
chip, etc. This can also be caused by the tray not being fully closed
on boot.
E66: DVD Drive Error: DVD model, or version does
not match that of the version expected by the dashboard. OR the
firmware version on the drive is older then the firmware version
expected by the dashboard. Make sure the DVD drive is of the same
version originally included with the console and that it is using
either the original firmware included with the console or newer.
E67:
Hard Drive Error... It could be a problem with the Hard Drive itself or
a problem with the internal connection to the hard drive, Try removing
the hard drive and playing without it
E68: Voltage
Error... This error means that the Xbox 360 has insufficent power to
function properly. This can be caused by an error in the hard drive or
the fans that make them suck up too much power, it can also be caused
if you have unnecessary accessories attached to the console like an
external fan unit. Attempt to remove unnecessary accessories first, and
then necessary components such as the hard drive and USB devices. If
you have any case mods you may want to investigate those as well.
E69:
E71: possibly a
dashboard update error, Check below in the "Console Reset Codes" for
instructions. If that does not work there is no other solution and the
console must be sent back to MS for repair.
E72: (not yet known)
E73: General Hardware Error: Ethernet port... this error is caused by a problem with the Ethernet port.
E74:
There is high chance it's a scaler chip problem (the "ANA" or "HANA"
chip near the AV cable connection) it can also be caused by a faulty AV
cable so check that first. In some cases it is a problem with the GPU
and may be repairable by doing the x-clamp replacement (see error 0102)
E76:
This error deals with the Ethernet port's controller chip, a dead chip
may not cause the error but removing the Ethernet controller chip does,
it may also be caused by other Ethernet related problems.
E79:
the hard drive and playing without it.
According to tmbinc: E79 is the error code if xam.xex could not be started, i.e. probably a file system corruption.
I have one red light appearing every time i switch my console on and a messege saying E72 ?
Does E67 mean that only the Hard disk has the problem? Not with the system?
Please help!!! It's very urgent guys!
