Re: When powering up a Poweredge 1600sc i get 6 error...
Hi, It states 1-3-2 = No memory installed Remove and reset the memory modules (see "Memory Modules"). If the problem persists, replace the system board (see "System Board"). Good Luck
I guess you can't go into start button. /anyway how did you know if computing is powered? On your keyboard top line keys have screen control keys for brightness etc.eg f4. try.
There should at least be a message on the monitor indicating there is no
signal coming to the monitor. The first thought that comes to mind if
all is connected would be that the power supply has failed. And maybe the graphic card.
Call also the DELL support in your country they will be glad to help and they probably know the fault.
Check the PowerEdge Raid Controller for parity problems. Sounds like the status on the physical volumes participating in a RAID array has been degraded.
Loud beeping from a drive is usually an indication that an invalid drive array member has resulted in a degraded logical volume.
If you were counting correctly, you had at least three drives - most likely participating in a RAID-5 setup. The array might have been rebuilt with one bad drive. But it sounds like you've got two corrupt physical volumes in the array. And that's not good.
Write down the exact number of beeps and how long they last to find what the error means. The are call BIOS post codes and they resemble Morse Code. (ie. one long, 3 short, 2 long = RAM issue) Good luck!!
Yes, some systems (newer PowerEdge Servers, generally 6/7th Generation and above) have onboard VRMs.
1600sc is a 6th gen PowerEdge (with Simple Computing). I can checked and be absolute certain from within Dell. I'm on VAC until Saturday.
In the meantime, check the PRC model and revision and ensure that they match. Given that a single PRC POST/Boots, try upgrading (if not already) the system BIOS to latest revision.
If the PRC model/revision does match and you have the latest BIOS version, also if the VRMs are not needed, then from the Troubleshooting you have already done, we may conclude that the PRC 2 slot is faulty.
I will confirm the VRM query on Saturday.
PowerEdge 1600SC, BIOS A12 Update Package for Microsoft Windows - http://ftp.us.dell.com/bios/PE1600SC-BIOS-WIN-A12.exe
PowerEdge 1600SC, BIOS A12 Floppy Update Package - http://ftp.us.dell.com/bios/PE1600SC-BIOSA12.exe
Mike
Disconnect from the network and all other accessories, and power up the system, this might be due to a faulty device attached to the system, eg: when you connect a usb faulty device the boot takes very long time, sometime it does not boot up.
