Refrigerators Logo
Posted on Feb 17, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The refrigerator side is warm
I have a frigidaire frost proof side by side refrigerator freezer model FRS26ZXH the freezer side is cold but the refrigerator side is warm.What could the problem be?
Thanks.
  • Anonymous Mar 23, 2014
    frost on rear wall
Anonymous
Level 3:
  • Master 770 Answers
  • Posted on Feb 17, 2008
Anonymous
Master
Level 3:
Answers
770
Questions
Helped
474887
Points
1794
Is there a heavy frost build up on the back wall of the freezer?? is the fan in the freezer working??
  • Kelly Jimenez
    Kelly Jimenez Mar 12, 2014
    The copper line gets a build up of frost and I have not pulled the frig out to watch the fan to be sure it is running. I think it is working
1helpful
FRIGIDAIRE FRS6HR4HW2 FRIDGE IS SOMEWHAT COOL BUT FREEZER IS SAME TEMP AS FRIDGE I HAVE POWER TO THE EVAP FAN BUT FAN IS NOT WORKING COULD THIS CAUSE THE FREEZER NOT TO GET COLD ENOUGH TO FREEZE
Yes, if your evap is fully frosted, and the fan is not working. The frosted evap will keep it cold but since the fan cant move the cold air from the evap it'll be cold, but not as cold as you'd like.
http://parts.sears.com/partsdirect/part-model/Frigidaire-Parts/Refrigerator-Parts/Model-FRS6HR4HW2/1428/0165000/R0607119/00005?shdMod=FRS6HR4HW2
there is the screen you need to order a new fan motor. option number 13 is the fan motor. lmk if u need more help!
Why are only drawers in fridge cold & not making ice?
Contact a professional. Sounds like either your damper door is not operating correctly and not letting enough cool air from the freezer enter, or there is an air leak that is making ice form .
Fridge warm, freezer frosted over and cold
Freezer fan motor is probably not working properly. Cold air is not being transferred from the freezer to the refrigerator.
2helpful
Freezer works but fresh food seems warm
If you have frost on the back wall of the freezer compartment you have a defrost problem. When the freezer coil does not defrost the refrigerator does not get air for cooling.
1helpful
2answers
Ice in the bottom of frigidaire side by side frost proof freezer
take all the bottom shelves and baskets out of the freezer. look at the back wall of the freezer. youll see a block of ice in a metal pan looking part at the bottom of the rear panel. there is a hole in the bottom of that pan. thats the defrost drain. its clogged. use a hair dryer to get all the ice out then use hot water to flush out the drain hole.
2answers
New Frigidaire side by side running constantly and still warm
If the frost build up is on the back panel of the freezer then it has a defrost problem which causes a no cool situation. Let me know more about this frost buildup and what you have done.
Top Frigidaire Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
john h
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
