HP LaserJet M3035 MFP Printer Logo
Posted on Jan 28, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My HP m3035 printer is making noise in the toner cartridge compartment on the right grinding sounds. I changed the Toner, still amking the noise any ideas?
Seeker5211
Level 3:
Genius:
  • Master 1,089 Answers
  • Posted on Jan 30, 2010
Seeker5211
Master
Level 3:
Genius:
Answers
1089
Questions
Helped
617730
Points
2611
Open the rear door. Power on the printer. Watch and listen as the fuser rotates. Does the noise occur when the fuser rotates? if yes - replace it. If you still think it's coming from the toner, remove the toner, close the toner door. When the motors start turning the noise should be gone. Insert the toner and listen again
  • Trip Brotehrman
    Trip Brotehrman Nov 13, 2013
    Replacing the toner did not help in my situation
My hp laserjet m1522nf makes a grinding noise and then says add paper' it also makes the same noise when i shut it down and power it up again ... does this mean the printer is garbage?
it could be a bad toner cartridge
try replacing each toner cartridge one by one to see if grinding gear noise goes away.
Or
it could be jammed paper somewhere inside the printer
3answers
How we can solved the hp lj p2055dn printer noise
Hopefully one of the first four suggestions helped you. If not if you could post more detail as to what kind of noise is the machine making: a grinding noise, a squealing noise, how loud is it. descriptions such as that would be helpful in diagnosing the issue. Without a description of the noise any of those first four posts could be relevant. The easiest thing to try first would of course be a toner cartridge I have experienced them many times making noises especially if they're aftermarket cartridges. Other than that grinding noises are typically fuser related in that machine, with squealing and high pitch noises the description of the noise is very important because it could be a fuse or it could just be dirt in a gear cluster rubbing on a shaft or it could be the laser assembly. Ireally hate to post absolute diagnosis without enough detail especially when it comes to you having to spend more money. Hope this helps.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/charles_45d8d6c78cd9f0b6
My HP M3035 is printing, copying & scanning extremely light but only after I changed th toner It prints fine with the old but with the new the print is light as if it were empty
You have a defective cartridge. It just happens sometimes, you should be able to return it where ever you got it for a replacement cartridge or refund.
Clicking noise
Check the printer thoroughly for any small pieces of paper caught on a roller in the printer. If your printer is making a grinding noise, you may have a loose gear or roller in the printer.
If the noises started shortly after you installed a toner cartridge, turn off the printer and pull out this toner cartridge. Look up into the printer where this toner went. Make sure that both the charge roller and the transfer roller are still seated in the printer properly.
  • The charge roller is a tan-colored or gray roller attached to the inside of your top lid. Remove the toner cartridge from your printer. Close the top lid halfway with the cartridge still out. You will see the charge roller come down as you lower the top lid. Make sure that the charge roller is installed correctly within the two black arms on each end and that the roller does spin freely.
  • The transfer roller is the black, spongy roller in the bottom of the printer, under the toner cartridge. Push lightly down on it at both ends to make sure it is seated properly in its housing. NOTE: Try not to touch the charge roller with your bare hands. It is susceptible to the oil and may cause a permanent fingerprint to remain on the roller surface.
  • When you have checked the charge roller and the transfer roller, look around inside the printer. See if you can find any rollers that look loose or broken inside. Also look for any loose shreds of paper. If you do find a loose or broken part, you printer will probably require service to fix the problem.
If the rollers look fine, go ahead and reinstall the toner cartridge. If the squeaking/grinding noise continues and none of the rollers looks out of place, try swapping out the toner cartridge. There is a small chance that the toner cartridge is causing the squeaking/grinding noise. If you have any extra toner cartridges in stock, try another toner cartridge and see if that clears up the noise. If you have another working printer of the same model, try swapping the toner cartridges. See if the problem follows the toner cartridge or stays with the printer.
If replacing the cartridge does not cause the noises to go away, there are a few other things you can do to help pinpoint the source of the noise.
If the noise continues on the main printer, try opening the rear exit door while printing. See if you can tell if the grinding noise might be coming from one of those rear exit rollers/gears. If it does sound like it is coming from the rear of the printer, again look for any loose or broken part or any small pieces of paper.
If you have added any additional feed options (like a tray 2 or 3 option, duplex option, or envelope feeder), please remove these options. Try printing a few prints without these feed options attached. This will eliminate one of the feed options as the cause. If the noise goes away when you remove the options, reattach them one at a time. If the noise returns on one specific option, a roller or gear on that option may be the cause of the noise.
Is your printer making a rhythmic THUMP - THUMP - THUMP - THUMP noise when printing? This noise is a side-effect of a feature called Envelope Enhance. The Envelope Enhance feature is built into the fuser unit of the printer to help keep envelopes from wrinkling. This sound is perfectly safe and normal if the printer is printing on envelopes.
If none of the above fixes eliminates the noise, the printer will probably need service to return it to working condition.
***If you need any technical help on printer then you can reach at here
2answers
Hp laserjet 5200 grinding noise from left side
front, rear ? I'd say fuser assembly gears or drum on toner cartridge; check the gear teeth on the toner cartridge's drum.
1helpful
2answers
Hello! I have got a 6 year old HP laserjet 3330 all in one laserjet printer.As soon as I switch it on, it makes a grinding noise. I think it comes from the a4 sheet feeder area. I tried lubricating...
I don't think the toner cartridge is amiss here. I think that on hp printers that are older, such as yours, the rubber feed rollers shrink and cause feed problems, over time.
My printer hp laserjet m3035 is printing blank pages
Try another toner cartridge. Make sure that the flap on the cartridge is not taped down. The flap should be able to open and close.
Hp laserjet 3330 gears on right side grinding after print
The most common problem with grinding is from compacted toner. Try changing the toner cartridge.
2answers
Makes grinding sounds & usually prints blank
Try new toner cartridge, or even the old one if you still have it. Check if the grinding noises go away.
k24674
Grand Canyon Tech
Grand Canyon Tech
