First four numerical digits in the Rheem Serial Number
Do the first four numerical digits in the Serial number (R0994B34120) of my Rheem, Electric, 30 Gallon, Water Heater stand for the date of manufacture?
the age of all water heaters is listed under the serial #, not model #. you will have to call a plumbing supply house that deals in your brand of waterheater, a.o. smith, ruud, bradfordwhite,etc.
1) Rheem 71-30 is 2-element electric water heater Reset button is located behind upper panel located on side of tank.
2) Rheem no longer shows that exact model number so your tank is older. To find age of water heater look at 2nd and 3rd digits of serial number, for example 06 is 2006
4) This water heater is fully repairable by homeowner using generic parts from hardware store To troubleshoot water heater: Requires $5 multimeter from Home center and about 45 minutes. Repairs take from 40 minutes to 1 afternoon, depending on skill and problem. Repairs cost $30-70 http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Add a comment for more free help. Also take advantage of fixya phone service. For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project. Fixya is always less expensive than a service call.
To find age of Rheem, look at 2nd and 3rd digits on serial number, for example 06 is 2006. Rheem normally uses 4500Watt bolt-in type element, available at home center or hardware.
Serial number should be on label on side of tank. Labels contain information like model number, tank capacity and BTUs First 4 digits of serial number are date of manufacture: for example 0604 is June 2004 Take photo of label for easy reading and for your records
Age of Rheem water heater is shown first 4 digits of serial number located on side of tank: for example 0705 means July 2005. Serial number also shows model number & wattage of elements in case you need to buy new generic 4-bolt type 4500 Watt element from hardware store.
B) 40 or 50 gallon water heater is 240Volts and tank will have 2 access panels on front. Rheem ships all water heaters with 4500 Watt elements.
Narrow down the suspects: C) Water heater has some hot water. This tells us upper element is working. And that water heater electricity is working. And that reset button is not tripped. And that heater is not experiencing run-away overheating event.
3) Burned or shorted wire. Turn off power. Open covers on side of tank. Remove insulation. Inspect parts for signs of high heat and burning. Especially lower element. Tighten any loose wires. Replace part that shows signs of burning. Put insulation and cover back over thermostats so cooler outside temperature doesn't cause thermostat to misread tank temperature.
