Amana PTAC cannot be turned on.
Amana PTAC model number PTC123B35AJ:
Unit cannot be turned on.
Status light is on, so we know the unit is getting power. But the light does not flash like it's supposed to. It is just steady on all the time.
  • 22 Answers
Sound like a thermister problem, however this may also be a circuit board problem, the system is controled by the outdoor board, check to see if you have a blown inline fuse in the outdoor unit, it will be under a red case in one of the wires.
Posted on Feb 01, 2010
SOURCE:
My amana ptac is not heating....the code "np" is displayed....how do I correct this...we just installed the unit and know little about operation. Thanks
I don't see this error code in the manual. I do see nP as an error code for Window Switch lockout. I just had this happen to me and they had me reset the control board.
Remove case, flick master switch to OFF for 10 seconds. Press Heat/Cool same time turn switch back on HOLD until off light comes on.
You should be fixed. Just had to do this for my unit. I was playing around with the settings and turned on the window switch option by accident.
Feb 02, 2013 | Amana In Wall Install Kit For Digismart...
I have thru-wall PTAC Amana PTH093B35AM unit. I
see if you can find a new board the power failure fried it
Jun 19, 2010 | Amana PTH093B35AM Thru-Wall/Window Air...
House wont cool ..tried to reset breaker in fuse box and breaker outside...this unit is only just over a yr old . the fan thing outdoors is not kicking on..
Does this unit have 2 breakers to it? The model you put down is a PTAC and generally just plugs in to the wall so it would have only 1 breaker. If I recall correctly it's got a 5 year warranty on parts so it may be worth it to check with your local HVAC tech and have them do a diagnostic for you. A good place to start would be Amana who can tell you the authorized service company in your area. They'll get the part for free and should roll the diag fee into the repair cost so you'll only pay for labor (if it even needs a part). Their sales and service number is: 1-800-647-2982. Here's a link to your warranty info:
http://www.amana-ptac.com/Home/Warranty/tabid/449/Default.aspx
May 27, 2010 | Amana PTH123B25AJ Heat Pump Air...
I have a amana ptc123B35AJ split unit. Used very little had heat on the other day than turn off. the heater came back on in the off position so I unplug from wall. Today I plug it back in but will not come...
theunit is in freeze protection.what you need to do is hold the t-stat buld to bring the temp up and it will come back on shortly.dont unplug the unit.when it gets to cald it goes into freeze protection so pipes in house dont freeze
Jan 12, 2010 | Amana PTH123B25AJ Heat Pump Air...
Looking for manuel reset on heater amana ptac unit heat won't come on new control board
I dont know about this model but in general electric heat wont have a reset button the heat is controled by a sequencer and each elememt has a safty limit switch incase the sequencer sticks in the on mode here is a link to where you can get more info on this model http://www.fixya.com/support/p51773-amana_ptc153b35aj_air_conditioner
Oct 30, 2009 | Amana PTC153B35AJ Air Conditioner
My Amana Confort Zone ptac unit with model number PTC 123A35AC will not drain...
there is a drain plug inside unit.pull unit out of hole and look down to right side of unit in the drain pan you will see a plastic drain port knock it out and the unit will drain
Aug 15, 2009 | Amana PTC153B35AJ Air Conditioner
Finding a less expensive cover for my ptac unit
These units are changed out quite often. You should be able to find you a cover on line. Try any ac parts web site. Russ You will need model number of unit.
Jul 23, 2009 | Amana PTH123B25AM Air Conditioner
Amana thru the wall ac unit won't turn off
The adjustment knob on the unit does not turn down how do you get the knobs off? Can we replace the control unit with one that is touch control? Could the problem of it not turning down be the thermostat? It is an Amana PTC153A35AD wall unit.
Jul 02, 2009 | Heating & Cooling
Heating & Cooling Logo
553 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Donni Steen
Marvin
Marvin
