Kenmore 14.8 cu. ft. / 419 liter Chest Freezer 11531 Logo
Posted on Jan 28, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Is it safe to plug a typical Kenmore kitchen refrigerator/freezer into a surge protector?
Anonymous
Level 3:
  • Master 443 Answers
  • Posted on Jan 28, 2010
Anonymous
Master
Level 3:
Answers
443
Questions
0
Helped
133246
Points
1441
Safety is not an issue, the problem you may have, depending on the surge protector, is that when the compressor starts up the amps drawn from the circuit is very high which could cause the surge protector to trip, then the power would be shut off to the refrigerator,NOT A GOOD THING!
Good luck !
110v surge protector that conserves power for freezer
A surge protector for a freezer is a good idea. To conserve energy? On paper it looks good but seriously only real savings are on bigger equipment.
I have a Kenmore Model # 253.62812202 refrigerator. It collects water at the bottom of the vegee and fruit trays at the bottom of the refrigerator which eventually leaks out onto the kitchen floor. Does...
It has a clogged drain tube and bottom trays is already full.
De-clogged it using a solid wire, match enough to penetrate the drain tube.
Insert solid wire slowly to the drain tube, back and forth.
Put water to clean and rinse drain tube.
Regularly check drain tube for clogged and tray for full water.
Good luck.
My Kenmore 9 upright freezer feels warm on the outside, what could be the cause. I have defrosted and cleaned it already and seems to work fine. however i am concerned with the outside temperature. Please...
This is normal. The condenser coils on freezers are typically located in the walls.
The refrigerator in your kitchen has condenser coils that are hot either under the frig or on the back. Freezers do not need as much heat transfer on the coils with the air so they put them in the walls, it is called a warm wall condenser. It may even feel hot to the touch if you happen to feel it near the end of a cooling cycle. It will be the warmest close to the compressor and cool off at it makes it around the cabinet down to the other side.
Can I plug my freezer into a surge protector
i know where your going and its a good thought
read your compressor, it will label the start up amp,
it may even be on the model label
it will give you the rated amps and the start up amps
this is current draw to run
as well as start up a stopped motor
depending on the age
most units use about
short of that use a 3x method
if it has the run amp x3 is startup
then read your surge protector if its rated higher than the amps needed to start the unit
then you should be fine
i will say most SP are rated at 15amps
my freezer is rated at 18amperes
What type of surge protectors can I use for my refrigerator and for my stove. Is there single surge protectors?
There are whole-house surge protection devices but they are not user installable. Find two electricians to give you a quote for your application.
The alarm keeps going off. Food is frozen fine just alarm
That alarm is there for a reason. Grab your owner's manual and see the different things it can mean. If the gas is getting low, that could be it, and you'll want to solve it as early as you can.
Sometimes a power surge or brown out can make that alarm go off. Try unplugging it for 5 minutes.
2answers
Working ff freezer unplugged 1 year now does not freeze
Hi!!! You seem to have a seal system problem..A leak of refrigerant or a restriction in the seal system..Good luck...
When plugged, kenmore freezer shorts the surge protector and outl
if thats the case should be an apparent wire off, somethings shorting directly to ground. the chest freezer has all of its wiring behind the access panel on the side of unit , no other wires in machine id look right there for something obvious
When plugged, it shorts the surge protector and outlets.
I noticed that my refrigerator, kenmore freezer2_bing.gif, and stove were all not on. This has not ever been a problem before, so I unplugged the surge protector and reset the outlet. I then plugged the refrigerator2_bing.gif and the kenmore freezer to the surge protector and I noticed when I plugged the kenmore freezer it just shorted the surge protector. I then just plugged in the refrigerator and oven to the surge protector with no problems. I tried to plug kenmore freezer to other outlet and same result "a short
1helpful
Kenmore upright - wont defrost, runs continuously and wont freeze properly
well don't be surprised, these electronic fridges run on dc electronics also and are sensitive to power surges. is this the freezer because there's no thermostats just the limit control. use a surge protector on the outlet to protect the electronics. if your still having problems get the limit sensors changed first (if applicable). if you want to go the safe way, I'd consider buying a surge protector and connecting it to the power.you can e-mail me with any questions @ [email protected]
Top Kenmore Freezers Experts
Jay Finke
Jay Finke
ZJ Limited
ZJ Limited
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
