Backbeat 903 headphones will not pair with my Windows 7, 64-bit laptop. The laptop recognizes the Backbeats, but can't find the driver. Now just got an error message -- 80004005
I had the same problem as you although I was able to find a solution. If your bluetooth adapter on your computer doesn't support A2DP then you can purchase this adapter from IO Gear: http://www.iogear.com/product/GBU421/
or another adapter that supports this feature. Windows will try to install it as a generic bluetooth adapter (which wont allow you to pair the headset) but if you install the disk that comes with this, it will also install the additional drivers needed for the headset.
Walmart carries it for $20 at most stores or $13 online. I got mine at the store.
http://www.walmart.com/ip/IoGear-Bluetooth-2.0-USB-Micro-Adapter/10299060
If you need help installing it let me know I can provide the steps I did.
TJB
i need help
I've found the ASUS Bluetooth utility works best with the IO Gear adapter. The IO Gear utiltiy has issues with Windows 7. Works well with Win XP though.
Get it here:http://www.asus.com/Networks/Accessories...
Bluetooth Headphones,for Gym,Runing,Exercise https://www.amazon.com/Bluetooth-Headphone-Charm-Exercise-Sports/dp/B01DUA9CA0/ref=sr_1_2?ie=UTF8&qid=1484100565&sr=8-2&keywords=Charm%2Bsonic&th=1
I want to use both the mike and headphones, so that I can use my soft phone on my laptop... will this work?
Jesse
Hey Robert, did you get it to work??? My headphones were working fine initially but after I paired it with my iPhone it doesn't seem to receive sound from pc even though its paired
Hey buddy i have all that but i still cant get it to work plz help
To pair
the Plantronics BackBeat 903 with an EVO 4G:
On the 903 headset:
With the headset powered off, press and hold the "Power/Pairing"
button until the LED indicator flashes blue and red. This will put the
903 headset into pairing mode.
Use the iPod Touch menu to search for the headset and select 9xxBackBeat.
(If prompted, enter 0000 for the PIN code/passkey. Some devices also
require you to accept the connection. Headset is paired when LED flashes
blue.)
On the EVO 4G:
Turn
the Bluetooth on from the Home screen, tap Menu, Settings, Wireless & Networks,
Bluetooth.
Pair
the EVO 4G by going to the Home screen, press Menu, Settings, Wireless &
Networks, Bluetooth Settings, Scan for Devices.
Follow the on screen prompts to pair the devices.
Good luck from Headsets Direct - 800-914-7996.
