Remote for Sony vcr will work for anywhere from 1 to 12 commands, then stops working (all commands); must slip batteries in and out for it to work again; remote & battery terminals are clean (used eraser & nail file), batteries are full (tried several replacement sets), no difference. All commands work (when the remote works), but batteries must be moved back'n'forth against remote contacts for it to keep working. (Remote # is RMT-V402)
Step 1: Entering the Code Number
1 See the supplied "Component code numbers", and find the threedigit
code number for the desired component.
If more than one code number is listed, use the number that's
listed first to complete the steps below.
For example, if you're setting up a Philips' VCR, you would use
the code number 035.
If your component isn't listed, see "Searching for the Correct
Code."
2 While pressing the SET button, press the
POWER button.
3 Press the button of the component that
you want to set up.
Note
On the VCR, CBL, SAT, AMP, CD, and DVD buttons, "video cassette
recorder", "analog cable box", "digital satellite receiver", "receiver",
"CD player", and "DVD player" are assigned respectively at the
factory. But you can also assign other components on these buttons.
For details, see "Changing the Component Type on the VCR, CBL,
SAT, AMP, CD, and DVD buttons."
4 Enter the component's code number.
For example, if you're entering the code
for a Philips VCR, you would press
5 Press and release the ENT button to store
the code number in the Commander's
memory.
6 Go to "Step 2: Checking if the Code Number Works" to finish
setting up.
1 Power on the component you want to set up.
2 Aim the Remote Commander at the component and press a button
to check if that button works.
For example, press the POWER button to see if it works on your
component .
3 Check that the other buttons of the Commander is operating the
corresponding functions of the component.
You can write down the code number on the label inside the
battery compartment lid.
If the Commander Doesn't Seem to Be Working...
• First, try repeating these setup procedures using the other codes
listed for your component (see the supplied "Component code
numbers").
• If - after trying all the codes listed for your component - you still
cannot get the Commander to work properly, try the search
method described in "Searching for the Correct Code."
These instructions came from the Sony RM-V310 Operating Instructions Manual. To Download the Full manual for FREE click HERE>
Thank you for taking the time "Grubhead", but this was not the problem, and no, no batteries ever leaked. Good suggestions though.
