Karcher 2500 PSI Pressure Washer Logo
Posted on Feb 17, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Karcher KB 499
My karcher is making a continuous pulsing pump noise, when you have stopped hosing. We seem to think it is the pump playing up.
  • 1 more comment
  • Anonymous Mar 11, 2008
    I have a Kharcher 360 high pressure washer, which surges when in standby mode, there is no sign of an external leak, I suspect a faulty valve, I have stripped the valve body but cannot find a fault, please help.
  • Anonymous Mar 15, 2009
    my pump also pulsing and i have lost pressure
  • Anonymous Mar 30, 2014
    Making a strange noise and leaking at bottom
    Making a strange noise and water coming from bottom
Anonymous
Level 2:
Champion:
  • Expert 313 Answers
  • Posted on May 25, 2008
Anonymous
Expert
Level 2:
Champion:
Answers
313
Questions
0
Helped
239021
Points
403
A high pressure had a pressure relaese valve may be the problem.
Anonymous
Level 1:
Problem Solver:
  • Contributor 14 Answers
  • Posted on Mar 04, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
14
Questions
0
Helped
10541
Points
14
Hi the pump surges when there is a leak on it find the leak that should sort your prob.
Hope this helps. Sean
Karcher K5 Premium Eco pulsing on low setting
Isn't there a bleed off valve on the unit. Typically they get stuck and pulsing is the result.
How do i stop it from pulsing?
Getting to much air to carb probably.
1helpful
2answers
I have a karcher kb9020 which pulses when idol any ideas why
The "manifold" as talked about above is also called the "Control head".
For a picture of the very small cracks in the control head see here: Karcher Control Head cracks
The video linked to below talks about the cracks in the control head at 7:00 through to 7:08. They guy incorrectly calls it the cylinder head in the video. How to FIX Karcher pressure washer
If Karcher made the control head from an aluminium casting, or used a metal insert near the point of failure, their product range would be a LOT more reliable.
1helpful
2answers
My washer makes a loud pulsing noise when not being used,as soon as I pull the trigger it works fine.
sounds like your unit has a bypass problem either needs adjustment or replaced
Karcher 620m wont work at high pressure
what you describe indicates a problem hose or block nozzle jet
if it doesn't play up with a normal nozzle then it is not the hose or jet but that particular wand and nozzle you are using
do you have a sufficient inlet water supply for the pump
2answers
My karcher seems to pulse when on, could this be due to the low water pressure from the hose?
I do not have specific experience of your machine.
However, the high pressure pump will be controlled by a pressure switch on the high pressure outlet to the pipe and jet.
Pulsing (turning off) suggests that the outlet (high pressure) pipe is blocked or partially blocked. Try checking the nozzle and (with the unit turned off) clearing it with a fine piece of wire.
Hope this works
Nic Williamson
2helpful
2answers
My Karcher pulses when on standby,stops when i use the trigger,but it also seems to have lost pressure.Is less than 6 months old but have lost receipt!
Is there a leak from the bottom ?
If so Problem, the leak is from the seam of the Manifold housing. There is a small crack in the seam. A design weakness.. A New Manifold Complete Replacement approx. $61.03.
If not you may replace the Pump Manifold Housing from Karcher, or locate a local Karcher Service Center.
If under 1 year old, and you can find a receipt,Karcher will replace the entire Pressure Washer under warranty.
5helpful
2answers
POWER CRAFT BY Karcher bought Aldi on 31Mar 05.2100Watts 130 bar.
You did winterize the machine? Leaving water in a powerwasher will freeze and damage the pump. It's a common happening, because people don't think of it or are not told by the maker.
3helpful
2answers
Karcher k7.80 pressure washr
I have a Karcher K 3.86 M electric PW with a similar problem: water leaks from the pump near the outlet and the pressure surges on and off continuously at intervals of 1-2 seconds. The leak appears to be coming from a very thin crack in the plastic pump head in what I think is the "unloader" valve portion. I read elsewhere that if you leave water in these PW's and it freezes it will crack, causing leaks. I don't know how you can empty all the water out so I think we must store these PW's in areas that won't freeze in winter.
Top Karcher Garden Experts
Sean Wright
Sean Wright
Sulejman Sulejmani
Sulejman Sulejmani
ZJ Limited
ZJ Limited
Are you a Karcher Garden Expert? Answer questions, earn points and help others
