This error is idicating that the fuser motor is not turning. Rotate the green fuser knob to see if it is hard to turn. If freely turning then a gear, motor, or DC Controller board is bad. If hard to turn then try to find what is keeping it from turning. The motor Assy is behind the cover right next to the fuser knob. Good Luck.
Rate my response!!
Thanks,
SF
See this thread...
http://www.fixya.com/support/t242028-error_code_e000014_0000
SOURCE: each time l switch on my machine canon ir3300 l have e000007-0000
Try this press additional functions,2 and 8 keys at the same time,additional functions,copier, function,clear,err.power off and on. If that does not work you will need a tech to fix your fixing unit.
SOURCE: error code e000733-0001
E733
0001 A fault is detected by the main controller PCB in the communication between
the DC controller PCB and the main controller PCB.
Main cause The connector has poor connection. The DC controller PCB is faulty.
Action
1. Connector, DC controller PCB
Is the connection between the connector J1015 on the main controller PCB
and the conductor J316 on the DC controlled PCB normal?
NO: Correct the connection.
YES: Replace the DC controller
what you need to do is just resetting your machine.
1. Press * 28 * on your machine in a quick move.
2. Select copier
3. Select Err.
4. Select Clear then press O.K
5. Turn your machine off for 1 minute and turn it on again.
The error code will not be there anatmoreand your machine will be functioning well.
frank
sir fixinig motor 0014 code is motor repering
fixing motor or lubricant the fixing unit
