SOURCE: haier washer won't start
1. does machine light up on control board? no. check breaker box or try plugging a lamp into the same outlet to see if it works. for this problem you may need a repair man to look at it.
SOURCE: error code 8
Could be water valve stuck open/ malfunction on coil. or possibly level control valve.
SOURCE: My Haier HW-C1460TVE-U washing m/c keeps giving (CLrF) ERROR Code
Anyway, my machine shows an error code "clrf". I just spoke to someone at Comet, and apparently this means there is too much foam in the machine. The machine will then refill with water and try to rinse it out, but if after that the machine still has too much foam in, then it will stop the cycle. Hence why my clothes are still wet (although I'd not realised they weren't rinsed properly either!).
I have not been using excessive amounts of washing powder, and usually use powder tablets or the liquid tablet sort, so they are a set amount and I don't do anything daft like stick 6 tablets in! I find it ridiculous that this would cause a problem with the washing machine, as I've used them perfectly fine with other washing machines.
Anyway, the advice from Comet was to keep trying different washing powders until i find one that foams less.
SOURCE: I have a haier hw-
The selector switch is most likely faulty and will have to be replaced. You can get parts, manuals, diagrams and more at partselect . com or daysappliance. I do recommend them. Repairclinic . com isn't bad either.
From my experience your timer has gone bad. You can test it with a voltmeter. If by slight chance the timer is good and has power to it, check the control panel for fault. That can be tested as well with a meter.
