HP Compaq Presario CQ50-110US Laptop Logo
Posted on Jan 28, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My touchpad scroler is do not working some time. When i restart,it starts working.How can i solve this?
Florin
Level 3:
  • Master 733 Answers
  • Posted on Jan 30, 2010
Florin
Master
Level 3:
Answers
733
Questions
0
Helped
166401
Points
1640
I advice you to reinstal the driver for it and test it, you can download the driver form official site selecting your type of notebook.
Toshiba touchpad frozen!
Check for a switch for the touch pad.
HP Compaq 2210b touchpad not working
go to control panel and mouse settings
adjust the sensitivity
then restart computer
let me know how this works
1helpful
It stopped working what to do to start it
1. The touchpad and external mouse drivers should be able to work together. Just make sure that you have the touchpad enabled. To see if you have the touchpad enabled, hold the Fn key and press F9. The combination Fn-F9 locks and unlocks the touchpad. If pressing Fn-F9 once, twice, thrice does not seem to lock/unlock your touchpad.. then you might not have the Toshiba hotkeys working or enabled. So lets forget it and try step 2. If Fn-F9 solved your problem.. there you go !
Arrow The way it works is you have to keep holding Fn key and have to hit F9 once, that should lock the touchpad. Again if you keep holding Fn and hit F9 again, that should unlock it and so on..
2. Sometimes this solves the problem.. Do a power cycle of your computer.. i.e., unplug the AC.. take the battery out.. Plug the AC back in and try to turn computer ON with AC alone (i.e, leave the battery out and just start computer with AC power).. Once windows loads up and everything is fine, then turn system off. Unplug AC.. put battery back in.. Plug AC back in and restart computer.. All should be working now.. if not, keep reading..
3. Click on START>go to RUN>type devmgmt.msc
4. Now in the Device Manager, click on the + sign next to Mice and other pointing devices. Right click on each device listed under "Mice and other pointing devices" and Uninstall ALL the MOUSE Devices you see listed there..
attention Make sure you ONLY uninstall the Mouse devices and not ALL devices from Device Manager like your CD, Display etc.. Just uninstall the devices listed under Mice and Other pointing devices after you have clicked on the + sign to the left of it..
5.Install Drivers
6. In the page that came up saying Downloads ( All operating systems, All categories ), at the top drop the list Filter by Operating System and select Windows XP (I am assuming you have XP.. if you have another OS, select that instead).. then on the right of it, drop the list Filter by Category and select Touchpad.. then click on the button "Apply Filters"..
7. Now you just see two drivers listed..
09-30-2004 Toshiba Utility
Touchpad Toshiba Touchpad Enable/Disable Utility for Windows XP (v1.27.0.3; 09-24-2004; 5.34M)
06-15-2004 Driver
Touchpad Alps Touchpad Driver for Windows XP/2000 (v6.0.303.5; 05-26-2004; 2.43M)
Click on the Download link on the right.. Save them to your computer somewhere in a folder or desktop, where you can remember.. After the files are downloaded, double-click on the file.. Unzip.. then Run.. and it will install the driver..
8. Restart your computer.. Now the Touchpad should be working fine.. Try Fn-F9 combination.. i.e, keep holding Fn key and tap F9 once, twice to see if it locks/unlocks the touchpad..
2helpful
2answers
My HP Mini 110 touchpad mouse is frozen. Pls help
Hello
If the touchpad does not responds then make sure that the touchpad lock switch (just above the touchpad) is not turned off.
If this doesn't work,Restart the computer and repeatedly tap the F8 key (you need to press F8 before windows starts to load) You should see a menu "Select Last Known Good Configuration" and press Enter.This should solve the problem if not,try to download the synaptics drivers for any of the Mini 1000 series laptop edition as you have a Mini 110. It does works.
Hi,sir i have hp laptop model pavilion dv5.my laptop touchpad is not working,i have chenged the windows few time,and also i reinstall my touchpad driver but the problem not solved,kindly to solve my...
Have you made any changes to your computer's BIOS (when you first turn on your computer, and before Windows starts booting up you'd hit F1 or the Delete key to get in)? It's possible the touchpad was disabled there.
Do you have an external mouse plugged in at the same time? If so, try unplugging the mouse.
Finally, try looking in the control panel at Device Manager (is the device recognized properly or is there a question mark next to it?) or the Mouse settings.
5helpful
2answers
Touchpad will not work
Hello, seems like a problem with the touchpad, first disable and enable the touchpad with the button which is located at the top of the touchpad, the corresponding LED should change from blue to orange and vice versa. If this doesn't solve the issue, reinstall the driver for the touchpad, you can find this by searching for 'recovery manager' in the start bar. Next step is to select 'advance options' and choose reïnstall hardware driver, there should be an option called 'Synaptics touchpad driver' select and install. kr Gijs
Dell Inspiron 1501 Touchpad locked up
Check the system setup F2 at start, and ensure the touchpad is enabled, next try an external mouse, see if it works.
If and external mouse works, the touch pad has failed and a new palmrest is needed.
Touch pad not working
This often occurs because automatic updates (a Microsoft solution) decides for you that you need a new driver for your touchpad. The driver is installed when you don't realize it and the next time your restart your pc it no longer works.
The first fix is to restore your system to an earlier date.
Click Start
Go To Programs
Find Accessories
then System Tools
Then System Restore.
When the dialogue box opens, choose to restore your computer to an earlier date; choose one that you are sure was a time when the touchpad worked, and restore. You will have to restart your system.
Good luck
tony
2helpful
My mouse button is lock how do i unlock it
5.Install Drivers
06-15-2004 Driver
If above doesnt solve it, then please post any errors that you get and I will see if we need to try something else. Thanks, CF
1helpful
3answers
Synaptics Touchpad Enhancements stops working
Hi!
I resently had the same problem on my HP laptop and search Google for possible solutions. No solution works until I tried Windovs Update and then got 5 alternatives - Synaptics PS/2 port TouchPad was one of them. I update and restart and finally solve this problem.
Terje
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
