I just bought my phone two weeks ago and now it is displaying the word COST 0 on the main menu. I was wondering how do you remove it from the main screen.
Setting the Day & Time
To change the time shown in the display, follow the steps listed below.
If you do not set the clock on your answering system, your messages on the
answering system may not have the correct time and day stamp.
Press MENU/SELECT.
Move the cursor to Day & Time and press MENU/SELECT.
Use and to select the day of the week, and press MENU/
SELECT.
Note: The day of the week does not appear on the handset display.
Use the number keypad (0 through 9) to enter the hour and minutes.
Use and to select AM or PM, and press MENU/SELECT. You hear a confirmation tone
Instructions: - Remove the handset from the charging unit. Press the "Mute" button to enter the "Main Menu."
- Use the "Volume Up/Down" buttons to scroll to the "Set Day/Time" sub menu and press "Mute" to enter it. "Monday," the default day of the week will flash on the screen.
- Use the "Volume Up/Down" buttons to scroll to the correct day of the week. Press "Mute" to select. - Use the number buttons to enter the correct four-digit time. Press the "#" key to switch from AM to PM. - Press the "Mute" button to save the settings and exit setup. The correct day and time will now be displayed on the screen.
i cant send or receive messages from my mobile, sony ericsson w100i . "Message Corrupt" is the message given when i open my inbox in a conversation mode. in normal inbox i can see an empty message. Before a week it showed "Out of memory delete messages" displayed. And i bought this mobile only before 2 weeks ago.. Please solve my problem.
hello,when it got damaged by dropping into water,did you try to dry up the panel before putting it on,if not that would have affected the panel and also the battery,does the phone still power on,if no,you will have to get a battery from a store or a friend who uses same kind of phone to run the test in powering it on.since the screen does not display any longer i suspect the screen is faulty or the pones flex,so you will have to get a new one the assumed estimated cost for both the screen and flex is about 30-50 dollars, please kindly rate the solution if it's helpful,
LG SECRET CODES: LG all models test mode: Type 2945#*# on the main screen. 2945*#01*# Secret menu for LG
IMEI (ALL): *#06# IMEI and SW (LG 510): *#07# Software version (LG B1200): *8375# Recount cheksum (LG B1200): *6861# Factory test (B1200): #PWR 668 Simlock menu (LG B1200): 1945#*5101# Simlock menu (LG 510W, 5200): 2945#*5101# Simlock menu (LG 7020, 7010): 2945#*70001# Simlock menu (LG 500, 600): 2947#*
LG-U81XX SPECIAL CODES Code to read phone version : - Phone without SIM - Enter 277634#*# or 47328545454# - Select 'SW Ver.info' Code to reset phone : - Phone without SIM - Enter 277634#*# or 47328545454# - Select 'Factory Reset' Code to enter UNLOCK MENU : - Phone wit SIM inside - Enter 2945#*88110# Test Menu 8330 : 637664#*# Test Menu 8180 V10a: 49857465454# Test Menu 8180 V11a: 492662464663# Test Menu 8130-8138: 47328545454# Test Menu 8110-8120: 277634#*#
MOTOROLA SECRET CODES
On the main screen type
IMEI number: *#06# Code to lock keys. Press together *7 Note: [] (pause) means the * key held in until box appears.
Select phone line - (use this to write things below the provider name): [] [] [] 0 0 8 [] 1 [] Add phonebook to main menu: [] [] [] 1 0 5 [] 1 [] Add messages to main menu: [] [] [] 1 0 7 [] 1 [] Copy SIM memory (phonebook menu): [] [] [] 1 0 8 [] 1 [] Eng Field options (main menu): [] [] [] 1 1 3 [] 1 [] Slow (Frequency of search menu): [] [] [] 1 0 1 [] 1 [] Medium (Frequency of search menu): [] [] [] 1 0 2 [] 1 [] Fast (Frequency of search menu): [] [] [] 1 0 3 [] 1 [] Enable EFR: [] [] [] 1 1 9 [] 1 [] Function : [] [] [] # # # [] 1 []
There are lots of similar codes exist. If you change the last number to 0 you can deactive that code. The 3 digit number at the middle are from 0 to 999. I put the most interesting codes. (EFR):Enhanced Full Rate Codec.
You can change GSM frequencies to 900/1800 by entering the enginnering model. Following the below steps: enter menu and press 048263* quickly, then you will enter the secret engineering menu under "Opcode" input 10*0*3 for GSM 900 10*0*4 for GSM 1800 10*0*5 for GSM 1900 10*0*6 for dual band GSM 900/1800 10*0*7 for dual band GSM 850/1900
To add extra message space 4 your Motorola C350 C450 C550 or C650, press menu button, press 048263* quickly, then on the popup menu enter 47 press ok.press 50 and ok.press 1 ok.press 64 ok.press 1 ok.press 186 and ok.You will receive an extra 50 msgs memory space.Switch phone off and back on.(not tested)
NOKIA SECRET CODES:
*#06# for checking the IMEI (International Mobile Equipment Identity). *#7780# reset to factory settings. *#67705646# This will clear the LCD display *#0000# To view software version. *#2820# Bluetooth device address. *#746025625# Sim clock allowed status. *#62209526# - Display the MAC address of the WLAN adapter. This is available only in the newer devices that supports WLAN like N80 #pw+1234567890+1# Shows if sim have restrictions.
*#92702689# - takes you to a secret menu where you may find some of the information below: 1. Displays Serial Number. 2. Displays the Month and Year of Manufacture 3. Displays (if there) the date where the phone was purchased (MMYY) 4. Displays the date of the last repair - if found (0000) 5. Shows life timer of phone (time passes since last start)
*#3370# - Enhanced Full Rate Codec (EFR) activation. Increase signal strength, better signal reception. It also help if u want to use GPRS and the service is not responding or too slow. Phone battery will drain faster though. *#3370* - (EFR) deactivation. Phone will automatically restart. Increase battery life by 30% because phone receives less signal from network. *#4720# - Half Rate Codec activation. *#4720* - Half Rate Codec deactivation. The phone will automatically restart
If you forgot wallet code for Nokia S60 phone, use this code reset: *#7370925538# Note, your data in the wallet will be erased. Phone will ask you the lock code. Default lock code is: 12345
Press *#3925538# to delete the contents and code of wallet.
*#7328748263373738# resets security code. Default security code is 12345
Unlock service provider: Insert sim, turn phone on and press vol up(arrow keys) for 3 seconds, should say pin code. Press C,then press * message should flash, press * again and 04*pin*pin*pin#
Change closed caller group (settings >security settings>user groups) to 00000 and ure phone will sound the message tone when you are near a radar speed trap. Setting it to 500 will cause your phone 2 set off security alarms at shop exits, gr8 for practical jokes! (works with some of the Nokia phones.)
Press and hold "0" on the main screen to open wap browser.
hai,
it seems your mobile phone and the SDmicro card are infected with some virus. try software upgrade using the PC suit
if its not working, contact the nearest service centre.
good luck
Put extension phone on base unit; press menu; press 0 0; press and hold intercom until charging light starts flashing. the display should show OK on the display screen of the extension phone; press OK. If you have more than one extension to add:
after you press 00; the symbol for # # # will come up. Enter a number for that extension i.e. 2; 3; or your choice.OK will come up on display at bottom right of display; press ok. hope this helps. This info should come on the extension phone and "menu" is on ext. unit. So turn the display up so you can see it while it is on base unit.
