I posted the site on tips and tricks where you will find the manual.parental control 8 is the default setting. the factory setting password(enter this in the new password bar)is 3351 and youll have to take it from there.it seems you have a password on your machine you can change it to your own with the factory setting number.good luck, SLEWEY.
Same problems with my unit. But, try this... I think it worked. First, you can not get to the setup screen for the unit with a DVD in the player. So, remove the DVD first: Unplug the unit, wait a few seconds, plug it back in. Then hit the DVD open button and remove DVD in player.
I think the issue with not reading certain DVDs is a problem with the "parental control" on the unit. Without setting parental control there were a few DVDs I could not play and sometimes (not always) I was asked about parental control before a movie would play. At the Sony Blue DVD screen, select Setup on the remote control. Select DVD setup and get to Parental control. Set a password. This will then take you to a "rating" screen. By setting the rating very high (I set mine for #8) any movie should play without needing the password. With no password set, you can not change the "rating" and hence mine was set at #1 (kids). It seems to have worked for now anyway. Good luck.
I entered the 3351 code and when prompted to hit Play to play disc, it freezes and I have to unplug it to clear buffer. I entered the code in the setup as well and nothing happened. I cannot play protected discs. Any help?
