The water will not drain from my drum. The spin cycle during the wash cycle works, but it will not do the final spin out. I believe it could be the pump, which is humming.
Re: The water will not drain from my drum. The spin
Check the filter, which is located at the bottom front right of washer behind a flap or drop down cover.
Unscrew anti-clockwise to remove and clean.
Please rate my solution.
Thankyou.
I don't believe you have a problem with your washer. It is NORMAL to have residual water in the drain lines and drain pump following a wash cycle. You will be able to hear the water sloshing around if you move the drum or drain lines. This is the lowest point of the drain cycle and gravity will ALWAYS cause some water to be there. As long as the water is not visible in the spin basket inside the drum, and the washer is properly draining during the wash and rinse cycles, you have nothing to worry about.
If you have any questions, please post back and let me know. I hope this is helpful to you.
Probably down to the water not emptying from the machine in the empty cycle and the machine won't spin because there's still water in the drum. If this is the case, the root of the problem is almost certainly a blocked filter, restricting the draining of the water and not allowing it all to pump out in time during the empty cycle. You probably need to find and clean your filter.
Take the drain hose out of the drain pipe and put it into a sink to test the machine
If that works make sure that the drain hose is being allowed to breath (ie let air into the main drain pipe so that the machine does not set up a syphon).
There is no problem, unless the drum doesn't spin at all. In a wash or rinse cycle there is a neutral drain just before the spin. During the neutral drain, the drum does not spin. If you open the lid or pause the timer during the neutral drain, the motor will stop (same as the short pause just before the actual spin) and the "kicker" in the transmission will disengage the brake. At this point the drum will start to spin. The neutral drain prevents wear and tear to the transmission since the drum will be very heavy while it's full of water and wet clothes. If it doesn't spin at all, you may have a problem with the motor coupling, the brake/clutch assembly or the transmission. Hope this helps to clarify things.
