Question about Whirlpool LSR6232J Top Load Washer
Washer won't move into spin phase on the Regular Cycle setting.
Whirlpool Heavy Duty Super Capacity Washer stops at spin in the Regular Cycle. Even when I try to manually move into the spin setting and pull out on the nob - nothing. However there aren't any problems with the Delicate or Permanent Cycles.
  • Novice4 Feb 19, 2008
    I was thinking that if the spin settings on the Delicate and Permanent Press Cycles were working fine that it would eliminate the lid switch as a source of the problem. I will try as you suggest and let you know what happens.
  • 770 Answers
Have you checked the lid switch??? This will prevent it from spinning look on the lid you will see a plunger.. watch where it goes down to you can use a pen to press the sw while the lid is up to see if it is working ...PS: dont forget to set it into the spin cycle first..let me know what happens
Posted on Feb 16, 2008
SOURCE:
I have a Whirlpool Heavy Duty-Super Capacity Plus, 7cycle/2 speed. Model LSR7200EQO , the agitator stopped working
My whirlpool heavy duty 2 speed 7 cycle washer machine stopped working, It fills up and aggitates for the first cycle then when it should drain and spin it doesnt drain nor spin
Jun 05, 2010 | Whirlpool LSB6200KQ Top Load Washer
My washing machine won't spin!
as with basic spin faults -a number of reasons usually 1 motor brushes, 2 motor 3 motor control pcb or the obvious one - the belt has come off.
Mar 13, 2009 | Whirlpool 3.2 cu. ft. Plus Washer
Washer spin & gurtitate no working
Coupling is broken that connects motor to transmission. Replace it. Please contact me if you need further help or leave feedback if appropriate as that is how I get paid. Thanks for letting me help you!
Nov 30, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Won't spin or agitate
coupling.between motor and gearcase.
Nov 11, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Washer Model LSL9244EQO
shut off water remove rear hoses pull screen from inside opening and clean ..BE SURE TO REINSTALL SCREENS..if still slow or stopped altogether replace fill valve..remove rear screws in console lift and roll console back unplug lid switch pop the clips on each corner up and off cabinet will lift off valve is top right side
Aug 06, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool LSR6232J Top Load Washer Logo
260 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
