I have a gas stove top with a griddle. The automatic igniter which lights the eyes will not turn off and is making a clicking sound. The only way to turn it off is to unplug it. The stove top is 18 years old. Look great and cooks great, what is my problem and how do I fix it?
Re: Igniter will not turn off. Makes a clicking sound
Hi, normally what causes the igniter to keep clicking is spilling water or something down into the knob area. The water is causing a short circuit in the switch which is mounted on each burner valve shaft. If unplugging the range for several days to allow drying doesn't fix the problem, then one of the switches will need to be replaced.
Could be the igniter isn't sparking, sometimes they get cracked and run to earth you will still hear it click. Remove the top plate and check the wiring and igniters, turn the lights off and you will see if it's sparking all over the place.
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good "blue" arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
I have a stove that doesn't light (click) I've replaced the igniters, I've replaced the knobs, and I've replace the box all the igniters and plugged into. There's nothing else to change out and it still doesn't give a spark. I've got gas and electricity but nothing will light
If it's two burners on the same side that won't light, it is probably the igniter for that side. If so, remove the grates, griddle, and griddle sub pan, and then lift up the main "pan (if it's like mine, it's hinged at the back and lifts up). Now, if each burner on that side has a tube going to the middle between the burners, the igniter is in that middle section. Mine is a small plug-in ceramic and metal part (see photo). If yours looks like this, contact me at [email protected], I have a spare.
gud day,the problem is ur igniter ligther is totally damage & nid to replace, if u want to use ur cooktop use matches or ligther every time open ur gas cooktop,tnx gerbee
