Use this. Spray it on. Make sure you only keep it on the glass. Wipe it off any metal trim. Cover the top with a sheet of clingfilm, (that stops it drying out). Leave it overnight and in the morning just wipe it with a none scratch sponge, rinse and polish. FYI, you can only damage a ceramic glass top by scratching it with something that is harder.
I believe the burn mark is some of the foil paper that got hot. I would try a wet and soapy rag placed on the stain and kept wet for several hours then with a scotch bright carefully see if it will come off. This may take several tries.
Since you are having problems with multiple elements the problem is probably the circuit board that controls them. This can be ordered and replaced. Be sure to unplug the stove before getting into the circuit board though.
use caustic soda power mixed with water and wallpater paste so its a thin jelly . apply with a brush and leave over night . rince with warm water on a clean cloth. use rubber gloves and glasses for protection
500g caustic powder
2 pints water
add wallpaper paste powder little at a time till jelly like
I recommend a product called of all things "barkeepers friend". It comes in a can with holes in the top to sprinkle the powder out of.
Moisten the stubborn area and sprinkle this product on the stain then add enough water to make a paste. Make sure the paste covers the entire stain. LET IT SIT FOR AT LEAST TEN MINUTES. Then rub with a wet cloth. It always works for me and I have a black stove.
If the water has been dried up, it was most likely the drip pans. Water is non flammable, sorry i couldn't help myself. If water was the problem there would be sparks and buzzing noises first.
There are some very effective commercial products available. One of the most highly rated is Cerama-Bryte, but BE SURE TO FOLLOW THE DIRECTIONS CAREFULLY....as once it dries it is impossible to remove!!!!! Work in small areas, rub consistently.
As well, mr. clean magic eraser also has worked magic on my mothers stove over the past few years also.
If you wish to stay away from the store-bought chemical....soaking the spots with water and ammonia OR vinegar..(not both) and elbow grease. As well....the razor blade in combo with the liquid.
Be sure to rank me.....please....especially if this Fix-ya`s....
