Well its a pain but there are release pins that are accesed were the pieces meet could be a small hole or ****. first try to unlock one side at a time. dont be afraid to get a little rough there a little tough to get back a part.
Can't you simply reverse what you did to do it correctly?
Hi, what is the model number??? You can find it on the inside of one of the legs when you adjust it to the highest level, on the underside of the plastic seat ring, the underside of the tray, or on the bottom of the saucer. I'll see what I can do.
Thanks.
Please respond to the previous question regarding your model number. I can't try to help you unless I have this info.
ok...I got the number.
https://plweb.evenflo.com/replacement_pa... Click on this link, and enter your model number and select a date...I selected feb 01 09, then click search and scroll down to line 20 and open the PDF file. This will show you the ring seat assembly and ring gear. It does appear that once it is snapped into place, it will be very difficult to remove and may require a second set of hands.
This was all I could find for a solution.
Hello. The only way to correct the problem is to disassemble the stroller, reposition the cover and then reassemble. A real pain for sure. Sorry there is no quicker fix for you. Regards, Joe
i know that is what i have to do... but what i'm not sure of is how to disassemble the seat... it seems on pretty tight...
model # 6163920
thanks so much for helping. I really hope you can find the solution 'coz i really want to use it for my daughter....
i tried, but you have to snap the seat in and now it seems impossible to take it out.....
