Cars & Trucks Logo
George Phillips Posted on Jan 27, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need to replace passenger side rear view mirror. I have new mirror. How do I remove inside covers on passenger door? 2007 Ford F-150 Supercrew.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 21, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
591
Points
How do I remove and install the inside rear view mirrow of a 1997 e320 mercedes benz
ren1221
Level 2:
  • Expert 194 Answers
  • Posted on Feb 05, 2010
ren1221
Expert
Level 2:
Answers
194
Questions
0
Helped
73892
Points
369
On the iside of the door theres a plastic cover it just pops off so you can take off the nuts
How to replace passenger door side mirror 2012 ford flex
The related help links are mentioned below.Click the link below:---
---------How to remove rear view mirror metal foot?
http://schematicsdiagram.blogspot.com/2011/12/how-to-remove-rear-view-mirror-metal.html
power locks, power window and power mirror on the passenger side not working on Ford Windstar
http://howtobyme.blogspot.com/2011/09/power-locks-power-window-and-power.html
----How to Remove Outside Mirrors on Acura Integra?
http://repairhelpcenter.blogspot.com/2011/11/how-to-remove-outside-mirrors-on-acura.html
-------Passenger side Folding Mirror is not operating? http://schematicsdiagram.blogspot.com/2011/12/passenger-side-folding-mirror-is-not.html
These will help.
Thanks.
I need to replace the mirror of my 2007 Ford Explorer XLT as it was hit and knowcked off, hanging by the power wires. this is he Passenger side door
You can access the inside mounting bolts by removing the panel just inside of the passenger mirror...the electric plug can be unplugged without any other changes...Your mirror is of course available through your local Ford dealer...you can also try the internet to find a like new replacement mirror and head assembly...just type in 2007 Explorer passenger side mirror...Also, your least costly replacement is available at your local salvage yard...some allow you to browse, and remove yourself...(good practise before scratching yours...some yards will pull the mirror for you...you might even find the exact color...salvage yard mirror heads (electric) go for $25. to $75. Sounds like you have a good start...Hope this helps.
Need instructions to replace the passenger side mirror and the driver side tail light on a 1999 Ford Taurus 4-door sedan. Thank you, Gary S.
Section 01-09: Mirrors, Rear View 1999 Taurus/Sable Workshop Manual REMOVAL AND INSTALLATION Procedure revision date: 06/25/1998 Mirror, Power-Outside Rear View Removal
  1. Disconnect battery ground cable (14301).
  1. Remove front door trim panel (23942). Refer to Section 01-05.
  1. Remove radio speaker grille from cover assembly by squeezing or pinching between thumb and index finger.
  1. Remove two screws from cover assembly.
  1. Disconnect outside rearview mirror wiring connector (C515-LH; C615-RH). Remove wiring guides as necessary.
  1. Remove three outside rear view mirror retaining nuts. Remove outside rear view mirror (17682) while guiding wiring and connector through hole in door.
Item Part Number Description 1 17682 Outside Rear View Mirror 2 N621906-S36 Nut (3 Req'd) 3 F8DB-17D699-
AAW Cover Assembly Rear Substrate-LH 3 F8DB-17D698-
AAW Cover Assembly Rear Substrate-RH 4 N808968 Screw 5 F8DB-18B984-
AAW Speaker Grille-Standard (No Badge)-LH 5 F8DB-18985-
AAW Speaker Grille-Standard (No Badge)-RH 5 F8DB-18K901-
BAW Speaker Grille-Mach-LH 5 F8DB-18978-
BAW Speaker Grille-Mach-RH 5 F8DB-238A35-
AAW Speaker Grille-Blank (No Speaker)-LH 5 F8DB-238A34-
AAW Speaker Grille-Blank (No Speaker)-RH A - Tighten to 6-8 Nm (54-70 lb-in) ------------------
Trim Panel, Door Front
Removal
  1. Remove cover behind inside door handle.
  1. Remove screw from bottom of pull cup retaining front door trim panel to front door (20124).
  1. Remove three screws retaining front door trim panel to front door.
  1. NOTE: Do not attempt to remove more than one pushpin at a time.
    Using Rotunda Windshield and Molding Trim Removal Kit 107-R0401 or equivalent, remove the door trim panel by pulling one door trim panel pushpin at a time from the inner door skin.
  1. Disconnect electrical connectors as necessary. Refer to Section 01-14A.
Installation
  1. Follow removal procedure in reverse order.
  1. Replace all pushpins with new pushpins (N808994-S).
Front Door Trim Panel
1helpful
How to replace Inside Rear View Mirror on 2000
Hello, to replace the rear mirror, try the following:
1. Roll the passenger side door window all the way down. Turn off the ignition and remove the keys.
2. Gently pry the window control panel from the arm rest with the pry tool or screwdriver starting at the bottom of the panel. Flip it over and unplug all the wire harness outlets from it. Set the panel aside.
3. Locate and remove the two panel door plugs near the arm rest concealing the two screws and remove the screws with the Phillips head screwdriver.
4. Remove the door panel retainer plugs along the edge of the door by pressing in the middle of the plug to unlock it and removing the plug.
5. Detach the mounting triangle from the upper inside door panel covering the side-view mirror.
6. Remove the door panel by lifting outward and then upward. Disconnect the speaker wire harness from the underside of the door panel and set the door panel aside.
7. Locate and disconnect the mirror wire harness.
8. Pull back the foam insulation from the inside panel covering the side-view mirror.
9. Unscrew the three mounting nuts from the mirror using the ratchet, extension and a socket. Do not drop the nuts into the door cavity.
10. Pry the mirror gently away from the outside of the door.
11. Install the new mirror and replace the mounting nuts on the mirror studs and tighten with the ratchet, socket, and extension. Plug the mirror wire harness back in. Replace the foam insulation. Replace the mounting triangle.
12. Replace the door panel by reversing the procedure. Start by plugging in the speaker wire first.
Thanks
Need a diagram for installing a drivers side electric power mirror on a 1995 mercury villager van
here's 1996, all I have. Please rate.
Mirror, Power — Outside Rear View NOTE: This procedure applies to both RH and LH power outside rear view mirrors.
Removal
  1. Remove the front door trim panel (23942). Refer to Section 01-05 for the removal procedure.
  1. Remove the two outside rear view mirror inside mounting hole cover screws and the outside rear view mirror mounting hole cover (17K709) from the front door (20124).
  1. Remove the wire clip.
  1. Disconnect the power outside rear view mirror electrical connector.
  1. Remove the three power outside rear view mirror bolts and the power outside rear view mirror.
Installation
To install, reverse the removal procedure. Tighten the three power outside rear view mirror bolts to 3-4 Nm (27-35 lb-in). Glass, Outside Mirror
Removal and Installation
Refer to the glass replacement procedures in Manual Mirror for power outside rear view mirror glass (17K707) Trim Cover
Removal
  1. Remove the front door trim panel. Refer to Section 01-05 for the removal procedure.
  1. Remove the two outside rear view mirror inside mounting hole cover screws.
    Remove the outside rear view mirror mounting hole cover.
Installation
To install, reverse the removal procedure. Mirror Control
Removal
  1. Use a small flat-blade screwdriver to pry the power outside rear view mirror control switch from the instrument panel (04320).
9helpful
2answers
How to replace passenger side mirror on 2007 Camry
To remove mirror pry off inside triangle panel(black) which exposes 3 nuts which are removed with socket wrench. Detach wire harness and pull out mirror assembly. To replace insert new mirror screws thru assigned holes and reconnect wire harness and tighten nuts to snug. Push inside triangle panel back into place and you're done! It's that easy.
2answers
I have a 2007 dodge grand caravan. I am replacing
the plug is inside of the mirror housing once you take the old mirror out if you need to plug it after the housing and you replaced the whole mirror the plug is inside the door panel
3helpful
Replace Passenger Side Mirror on 2002 Ford F-150
On the inside trim, you can remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. You'll need to lift the door panel upwards in order to get it off the window ledge. Then you'll need to manipulate the panel and disconnect the door handle linkage from the door handle and disconnect the wiring for your controls. Then you can access the bolts that secure the mirror onto the door
HOW DO I REPLACE THE DRIVER SIDE POWER MIRROR ON AN 98 F-150?
Remove the sail panel,the little panel on inside of door at the mirror.
Remove the window regulator switch plate, pry up on the front of it with a small pick or screw driver. Disconnect the electrical connectors.
Remove the top door trim panel screw that is behind the sail panel you removed.
Remove door trim panel screw at window regulator switch plate opening.
Remove door trim panel screw in the courtesy lamp housing. Remove the courtesy lamp lens.Remove the screw.
Remove the inside door handle trim cover.
Remove the bolt.
Remove the inside door handle.
Lift upward to remove the front door trim panel.
Remove the courtesy lamp.
Turn the courtesy lamp bulb socket one quarter turn and remove.
Disconnect the power mirror electrical connector.
Remove the three outside rear view mirror nuts.
Remove the mirror.
2answers
I need to replace the passenger side mirror on my 2006 F-150. I have the new mirror....does the inside door panel have to be removed or is this job done from the outside?
you need to remove the little black plastic cap on the inside remove the electrical conection and then remove the bolts place the new one in it's spot making sure that the gasket sits right or it will leak when it rains and place the bolts back without over tighting it or they'll snap plug electrical back in and place the plastic cap back on. hope this could help you.
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
