Question about Cellular Innovations HFBLU-CX1 Wireless Headset
Pairing code I lost my code for my blue tooth miniblue hfblue-cx1 and can't pair it wiht my cellular phone.
  • 1 more comment
  • bigman1980 Apr 03, 2008
    I lost my code for my headset .
  • jaxfromnc
    jaxfromnc Jun 12, 2008
    Same here.
    I lost the passkey code for my cellular innovation's Mini blue bluetooth headset. Can you help?
    Jackie
    jaxthe1@bellsouth.net
  • carmen_valen Nov 14, 2008
    i tried using 1234 passkey and it says it is verifying passkey but its taking 3 minutes already is that how long it takes?
Try 1234 or 0000. Mine is 1234
Posted on Apr 21, 2008
Found it. it's 1234
Posted on Feb 17, 2008
That doesn't help me. I have a Samsung sgh-t329, which automatically searches for bluetooth devices. Any suggestions?
Posted on Jul 14, 2008
Thanks Mr NO,that was it!!
Jax
Posted on Jun 12, 2008
SOURCE:
LOST PASS KEY
Most blue tooth manufactures use a 4 digit pin pairing code they are as follows 0000,1234,1111,or 9999 i hope this helps
Feb 18, 2011 | Cellular Innovations HFBLU-CX1 Wireless...
I need need pas key for plantronic 220 pairing to a blackberry 8300. jguyden@ccny.cuny.edu
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
Sep 14, 2010 | Cell Phones
I have lost my Bluetooth manual and have switched phones. How do I reprogram it to the new phone?
Hi,very easy.It's just the same way you paired the blue tooth with the phone.Dothe same with the new phone are you are done.
Have a nice day.
Sep 01, 2010 | Cell Phones
I WOULD LIKE TO SET UP A BLUE TOOTH CONNECTION
Take care.
Aug 20, 2010 | LG Shine CU720 Cellular Phone
I go to the bluetooth menu and turn it on. it says "Bluetooth turned on" But the icon fails to appear and file transfer fails.
HOW TOCONNECT BLUETOOTH
Take care.
Aug 16, 2010 | Sony Ericsson K550i Cellular Phone
How to connect a blue tooth with cell phone
Take care.
Aug 08, 2010 | Cell Phones
How to connect sony ericsion w395 via blue tooth
Take care.
Jul 07, 2010 | Sony Ericsson W395i GSM Quadband Phone ...
Bluetooth not working in sony W580i phone
After attempting on this process, if doesn't work,that means thee blue tooth is corrupted and to restore bluetooth, you will to flash the phone. Flashing the phone will restore back blue tooth.
You can use this links to see how to flash your phone.
hubpages.com/hub/How-to-Flash-your-cell-phone
and
unlocktotalk.com/UnlockCodeInstructions.htm.
Take care.
Take care.
Jul 03, 2010 | Sony Ericsson w580i Cellular Phone
Plsits just that my phone's bluetooth refuse to work. It says 'unable to perform bluetooth operation'. Wat can i do to get this prob solved?
first reset the phone and try to connect again.
If it connects,you can use this step to,But if it doesn't connect that means the blue tooth is corrupted and will need to be flash to restore back blue tooth.
(You will have to flash the phone to restore the memory of the phone.
You can use this link to see how to flash your phone.
(hubpages.com/hub/How-to-Flash-your-cell-phone)
and
(unlocktotalk.com/UnlockCodeInstructions.htm.)
HOW TO CONNECT BLUE TOOTH,
Take care.
Jun 28, 2010 | Nokia N73 Cellular Phone
Need the pairing code for the Mini Blue
I fit is the H5 Miniblue, the pairing code is "0000"
Nov 20, 2009 | Cellular Innovations HFBLU-AX1 Bluetooth...
Cellular Innovations HFBLU-CX1 Wireless Headset Logo
309 people viewed this question
Top Cellular Innovations Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Cellular Innovations Radio Communication Expert? Answer questions, earn points and help others
