Kodak EasyShare V1003 Digital Camera Logo
Posted on Jan 27, 2010
Problem with LCD. I need to replace it now. What is the cost of LCD for V1003 model of Kodak Easyshare camera
5 Related Answers
A
Anonymous
  • Posted on Jan 07, 2008
SOURCE: Kodak EasyShare C743 Digital camra has cracked LCD
Buy a used camera on eBay that has a good screen and change it yourself. It is very simple to do and here are the instructions on how to do it.
http://www.clickondavid.com/LCD7430.pdf
I have done this and it works just fine if you follow the instructions.
Anonymous
  • 7 Answers
  • Posted on Feb 08, 2008
Call up Kodak at 1-800-431-7278 select option 3 and they gave me a price for my C743 of $44.35 + $15.00 shipping, but still no luck on the internet but cheaper than a new camera.
sharcnet
SHARCNET-USA
  • 2130 Answers
  • Posted on Feb 11, 2008
SOURCE: Damaged LCD Screen
The following procedure works on the V1003. It uses the same LCD screen as the V803.
It would appear you have a damaged LCD screen. The same problem happened to my daughter's V803. The camera will take pictures fine but you will only be able to see them if you download them onto a PC. A replacement screen can be easily ordered and replaced. Call Eastman Kodak. Their parts department can be reached at (800) 431-7278 ext 3. Tell them the model number of your camera and tell them you want to order a LCD screen for it. The cost of the new screen is $31.00 + $15.00 shipping. Don't let them talk you into sending it back for repair. You are looking at a repair bill over $80.00. To replace the screen, remove all of the small philips head screws that are in the chrome band that runs around the center ridge of the camera. After removing the screws, you will be able to separate the rear half of the camera from the front half. The LCD screen is pressed into a rubber gasket in the rear half of the camera. You will see that there is a small, flat orange ribbon cable that connects the old LCD screen to a black connector on the camera's motherboard. Using a VERY small flat blade screw driver, pry up the top tab on black connector. This will unlock the connector and allow you to remove the flat ribbon cable from the black connector. Remember the orientation of the old screen and its cable as you will want to replaced the new screen and cable exactly the way the original was installed. Using the same small flat blade screw driver, pry out the old display. Install the new display into the rubber gasket into the back half of the camera. Insert the ribbon cable into the mother board's black connector and press down on the panel to lock the cable into place. Lay the rear half of the camera face down on the table (rear buttons facing down) and place the front half of the camera over top of the rear half. This will allow you to put the camera back together and help prevent the new LCD screen from falling back out. The LCD screen has pads attached to the surface behind it. When you reinstall the front half of the camera, those pads help hold the LCD screen in place with pressure from the motherboard. Replace all of the screws. If you did it correctly, the camera will operate like new. Last word of advice. Buy a padded hard shell case for this camera. These cameras are well known for LCD screen failures due to shocks and drops.
Good Luck!
- Jim
Anonymous
  • 18 Answers
  • Posted on Sep 13, 2008
go to www.buy202.com the lcd is $39.00 with free shipping and you can replace it your self its pretty easy i did, just need a eye glass screw driver. hope this helps
Anonymous
  • Posted on Nov 26, 2008
SOURCE: Kodak EasyShare CX7330 LCD Screen Replacement
darntoothysam.com can help
I need a manual for my EasyShare V1003 ? Where can I obtain one? Can download the basics of operations for it ?
Getting started guide:
http://support.en.kodak.com/app/answers/detail/a_id/18750/kw/v1003
User's guide:
http://support.en.kodak.com/app/answers/detail/a_id/18747/kw/v1003
What is the email add of kodak service center found in makati city.. I really need it badly for my broken lcd sa kodak easyshare V1003.. please help me..
Kodak are not represented in the Philippines any more.
The nearest English language centres in your part of the world are:-
India
Australia
New Zealand
(the above links all have identical looking pages but are to the individual territory sites: but probably all answered by the same team anyway)
Note that as the v1003 is a low cost consumer level product as per almost all Kodak models, getting them repaired outside of any warranty is usually not cost effective.
Good luck and I hope that you achieve a satisfactory outcome. Please take a moment to rate my answer.
Feb 24, 2010 • Cameras
How do I change the lcd in a Kodak v1003
KODAK does not sell spare parts.
If you would like to attampt to change the LCD yourself make sure the cam is OoW. since the manufactors warranty doesn't cover if non authorised KODAK TECH attempts to repair.
You might be able to find a faulty V1003 on sale on the Net and use this for spear parts.
An OoW. repair for a V1003 though KODAK is 88,07 pounds. But KODAK does offer a Trade up option where you for a favorable price can exchange your faulty camera for a brand new camera for a favorable price.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
My LCD screen has a dark spot
The screen must be replaced. To do it yourself, the screen will cost around $40 from virtualvillage dot com. I just did one. It took about 15 minutes. The ribbon cable is held in by a flip up lock on the main board. Otherwise, it's just remove the screws around the case and pull the bottom edges outward first.
virtualvillage uses Pay Pal only.
Cracked screen
no the screen is not worth gettin fixed the lcd scrren usaually cost more than the camera itself does but if your camera is discont get it fixed because their will be no other camera like it
Lcd on v1003
The instructions work for both the V803 & V1003. They are basically the same camera, using the same LCD screen, the V1003 has a higher Megabyte resolution.
- Jim
SHARCNET-USA
Lcd cracked and bleeding spot down left part of screen
Go to www.kodak.com look for the customer service link or look for contact us ,then call and they will give you a return number
Hope this was of help!
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
