MSI PM8M-V Motherboard Logo
Posted on Jan 27, 2010
MSI N1996 , no dirctx 3D enabled, when i run DxDiag
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 27, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
308
Points
How to download driver mb msi N1996
No display in MSI N1996
central processing unit CPU
as it says it processes all information that runs a computer
hope this helps
Ill be watching a video on youtube then all of a sudden the video goes all gray and you cant see the video but you can hear the audio
click start, click run, type dxdiag, press enter, then click display, disable the 3d acceleration if it is enabled.
My VGA card can not perform 3D applications, just only 2D
well then in this case u can do one thing
press windows key+r
type dxdiag
go to the display tab on the top
chk if direct draw and direct 3d is enabled if not enable them
if they are already enabled hit the test button next to both and check wat it says
this shld work
3helpful
Autocad problem
Sounds like you need the latest version of directx installing.
Get DirectX from Microsoft here >>>>>>>>>
http://www.microsoft.com/downloads/details.aspx?FamilyId=2DA43D38-DB71-4C1B-BC6A-9B6652CD92A3&displaylang=en
To check to see if your 3D accelerator is enabled go into DXDIAG (type DXDIAG in the run or search box),
go to the DISPLAY tab, see if Direct3D Acceleration is ENABLED.
Finally make sure that you have the latest video drivers installed
Regards.
59helpful
9answers
MSI N1996 VIA VT8237A VGA DRIVER
i cannot connect to my screen from VGA card
7helpful
2answers
I want a sound driver for MSI mother board MSI N1996 (MS 7101 VER 2.B) and thanks for all.
MSI's website has drivers for your board.
Try this link
http://www.msi.com/index.php?func=downloaddetail&type=driver&maincat_no=1&prod_no=190
Let us know if you run into any bumps
Having trouble playing game
You might need to update you version of DirectX by going to the microsoft site, or make sure that the 3D accelleration is enable in DXDIAG.
If using XP go to Start>Run (on the right hand side) and type in dxdiag then press enter. When the program opens click on the display tab and check that the 3D accellarator is enabled. Also carry out the tests within the display tab to make sure that there are no other errors. Check the game for the version of DX that it need against the version that you have, your version will be displayed when the dxdiag program opens. I hope this helps
Lineage2 critical error problem
type dxdiag in run window and follow instructions for enabling 3d acceleration
Installed Call of Duty World at War,Cliked on Solo play but screen goes back to desktop. I have updated my graphics driver. My system is a Dell XPS 710 With a Radion X1950 Cross Fire Graphics card,Quid...
What are the Direct X recommendations for the game? Is your direct X up to date.?
You can check if your graphics card is compatible with 3D graphics by going to Start>run (just on the right below search), and type in dxdiag,
This will bring up your direct X diagnosis program and enable you to run some checks.
Check to see if 3D graphics Accelleration is enabled and then run the video and sound checks to make sure that you are having no problems.
I can,t install 3D acellerator
In the run box, type in dxdiag then enter.
Go to the display tab and see if the Direct3D is enabled, if not enable it and also while you are there do the tests.
If you can save the log and copy and paste it here if that doesnt reslove the issue.
Top MSI Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
