These maybe the the problems:
1) Check weather the charger is switched on.
2) Check weather there is low voltage or high voltage.High voltage can damage your psp or the charger.
3) Check weather your psp is in full charge.The lights may not switch on if you have full charge.
If you have checked all the above you better buy a new one OR buy or borrow a usb cable, connect your psp to a laptop or pc.But before going to usb mode go to system settings in settings and set usb charge to ON.And now you can charge your psp while your in usb mode.The light will turn orange if it doesn't there is a problem with your psp.
