Question about Sony 4GB Memory Stick PRO Duo Memory Card
Unable to format - Sony 4GB Memory Stick PRO Duo Memory Card
    President:
  • 281 Answers
LLFTOOL is a utility for low-level disk drive formatting,
also supports formatting of FLASH cards using a card-reader.
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Posted on Feb 04, 2010
SOURCE:
My hard drive is unable to open and format
You will probably need to remove the drive and use another computer to format it. You can buy an adapter to connect it to another pc as a USB drive and format it this way. They are not very expensive. Hope this helps.
Jul 17, 2010 | Toshiba Satellite A215-S4747 Notebook
Unable to delete data or format or partitioning samsung HDD
Have you tried booting from a Windows XP CD? If you have one available you can boot from it, delete the partition and format it. Works all the time for me.
Jul 30, 2009 | HP Computers & Internet
It is unable to format and it shows "device was unable to complete the format"
Go to my computer scroll to sansa or your MP3 player and open the music folder and open each sub folder and delete Songs manually then delete the folders them selfs then format a couple of times hope this works
May 24, 2009 | SanDisk Sansa e260 MP3 Player
Unable to format the cruser pendrive
Far too often these little things have an almost invisible read/write protect button on them. Look carefully, over the entire surface of the USB Flash Drive. You might have this switch turned to Write Protect, which means there is nothing you can do, until you turn it the other way, and allow the device to be written to.
Cheers!
-a.
May 22, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Windows was unable to complete the format 16gb kingston flash drive
windows was unable to complete the format flash drive
Apr 28, 2009 | Computers & Internet
Unable to format
Try this trick; if there is an option for quick format. Format it first on quick format option. Then format it using full format.
Apr 24, 2009 | Dell Dimension 1100 PC Desktop
sir
u dont need to buy a new one. You can download file shredder from here . do following things :
  1. download and install file shredder
  2. shred all the files which are in pendrive(after shredding u will not be able to recover them)
  3. then try to format it .,
thankyou for using fixya
dont forget to rate the solution
have a nice day
Mar 12, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
windows was unable to complete the format 4gb moser beer
Feb 26, 2009 | Electronics - Others
Unable to format
Try quick format, it should work...!!! Else use DOS to format..!!!
Feb 10, 2008 | SanDisk Sansa m230 MP3 Player
Sony 4GB Memory Stick PRO Duo Memory Card Logo
273 people viewed this question
Top Sony Electronics - Others Experts
 Grubhead
Grubhead
Argospete
Argospete
Are you a Sony Electronics - Other Expert? Answer questions, earn points and help others
