SanDisk Cruzer Micro 4GB USB 2.0 Flash Drive Logo
Anonymous Posted on Jan 27, 2010
How do you reset the sandisk Cruzer Micro 4GB USB Flash Drive? I cannot figure out how and even though I deleted everything on the usb it still says that I only have some MB's left and it will not put any files on the drive because error saying it is full but it is not? How do reset it my usb drive? Please help me
  • Anonymous Jan 27, 2010
    Thank-you very much. That was excellent help and was easy to do thank-you willell.
Anonymous
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • Expert 67 Answers
  • Posted on Jan 27, 2010
Anonymous
Expert
Level 2:
Mentor:
Answers
67
Questions
0
Helped
20565
Points
188
Go into my computer, rightclick the drive, click format, select ntfs or fat 32, give it a name, use quick format and click format again.
Testimonial: "Wow that was easier than I expected thank-you very much willell."
1 Related Answer
A
Anonymous
  • Posted on Feb 09, 2008
SOURCE: sandisk cruzer micro 4GB
it may be because of the usb port of the system or the usb of the pendrive.................
REMOVER SD CARD
There isn't a memory card in the Cruzer. It contains a memory chip similar to what's inside a SD card. Even if you managed to extract the chip without damaging it, you'd need a different controller.
Formata pen drive 4gb
connect it to PC then... go to My Computer icon on desk top >> right click >> manage >> Disk management >> select ur SanDisk Cruzer Micro 4GB USB 2.0 Flash Drive >> right click >>format ....ok......
1helpful
How can I erase the Sandisk Cruzer Micro 4GB USB menory stick? I deleted everything on there but it still says that I only have a few MB's left even after emptying the trash. I work on a Mac using OSX. I...
Try to format the stick.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "flags".
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Sandisk U3 Cruzer Micro 8Gb Cant Format :S
rite click on it in mycomputer and click propertys to see if your thunb drive even has memory on it could have ben fried by sum and has no memory now
1helpful
3answers
How to use flash drive
Cruzer Micro is an USB external memory where you can store files.
It is automatically detected and installed on all Windows OS from Windows 2000 onward, same on Mac OS and recent Linux versions.
All you have to do is plugging the device into USB.
After the flash drive had been automatically installed , it will be displayed under Computer as an external disk.
You can copy and transfer files using Cut, Copy and Paste functions, or Send to function in windows, or the file manager, depending on the OS used.
In Windows, before unplugging the memory from USB , it is better to turn off the computer or use the 'safely remove USB' function located near to the clock, on the lower right hand corner.
Read also the documents below:
Introducing the Cruzer Micro
Find Answers || BeCompliant Corporation
How to Use Sandisk Cruzer Flash Drive
Cant detect my flash drive
Have you tried installing the driver for it on your computer?
1helpful
Cannot remove write protection on sandisk cruzer usb pen.
The memory cards also have a write protection switch to protect data from being deleted or overwritten, just like a floppy disk
Cannot delete photos from my SanDisk Cruzer Micro 4GB USB 2.0 Flash
First thing i would do is try to do a checkdisk in windows. Double click my computer > right click the thumb drive > click properties >click tools> click checkdisk. If all comes up ok with no errors try formatting the drive.
Let me know!
Top SanDisk Electronics - Others Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
