ViewSonic PJ501 Multimedia Projector Logo
Posted on Jan 27, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My blues are green on my projector. do I need a new bulb?
jasbo
Level 3:
  • Master 2,239 Answers
  • Posted on Jan 28, 2010
jasbo
Master
Level 3:
Answers
2239
Questions
Helped
991224
Points
5072
Reset the settings to factory default and check the lamp for bulges, black spots, fogging or flaking, and replace as necessary. if not better, you may have a fried polarizer on one of the lcd panels due to excessive dust and heat. that will need to be replaced, buy you may have to replace the entire optical engine, as many manufacturers don't sell the individual parts.
My projector has lines on the screen. new bulb didn't help
If this projector is connected by Component Video (3 or 5 wires) instead of HDMI, the most common color related problems are caused by having one of the 3 video cables (Red, Blue or Green) with a bad connector. If everyone is a green smurf the problem is with the red cable. If everyone is a red smurf the problem is the blue cable. If the green was bad you wouldn't see anything.
Another possibility is if the green is plugged into the yellow jack instead of green jack on the projector, you could see what you are describing.
If everything checks out, take the projector to a repair facility.
If you are connected by an HDMI cable, (combined with the fact you mentioned vertical lines not horizontal) then take the projector to a repair facility.
All of this assumes that you don't just have a bad Cable Box or Blu-ray player or Home Theater Receiver. (The source)
Image looks doble in colors.Gren,Blue Red
Depending on how severe it is, it can be fixed. I can do the repair if you'd like.
5helpful
Projection has yellow tint
From your description, it sounds like a problem with the blue color. Green LCD=purple onscreen, Red=cyan(baby blue) onscreen, Blue LCD=yellow onscreen. It could be a lot of dust on the blue lcd panel, or worse, might be a burned polarizer filter behind the lcd panel due to excessive heat. If you can focus on the yellow and its tons of yellow specs, its dust. A burned filter however, must be replaced. A technician trained in projectors will have to do it. The filter material is glued to a thin glass panel and is replaced as a single filter. It's a very involved repair.
2answers
NEC Multisync MT1000 Projector - Green Hue
its not the bulb problem . the lcd block need sto be replaced , better to buy new projector
1helpful
Bulb not coming on?
Hi - You can download the manual by clicking the link underlined in blue below:
PT-AE900U
Most likely the air filter needs cleaning. See page 55
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
2answers
Projector Problems
There is some problem in your LCD Panels. Service the optical unit ant retry.
regards
Viren
Mitsubishi XL8U Projector
Hi terry2421
No this is not the bulb. You will have to get the Mainboard repaired at a service provider. Losing signal and a discolouration showing up is a clear indication of a faulty Mainboard.
Get a quote first , because some service providers overcharge on these sort of repairs. The most you should pay is $150.
3helpful
2answers
Growing blue patch
you have to replace prism it has 3 small lcd screens Green Red Blue one of them is beginning to burn they are very expensive strip projector down with no power connected and take damaged screen of then block that area so no light can pass through it with fire resistent material you will get some more life out of it
Top ViewSonic Office Equipment & Supplies Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a ViewSonic Office Equipment and Supply Expert? Answer questions, earn points and help others
