CHECK THE VOLTAGE ON THE MOTOR BY CHECKING THE 2 LINES! SEE THAT MOTOR IS SET ON THE RIGHT VOLTAGE, DO A AMP CHECK, MAKE SURE THE START SWITCH IS CENTERED, HAVE THE START CAP TESTED . OR BING IT TO YOUR LOCAL POOL PUMP REPAIR GUY WITH FREE TESTING... THAT WOULD BE ME ''
IT'S IN MY DNA TO DISASSEMBLE IT, ANALISE AND MODIFY TO PREVENT FUTURE PROBLEMS . MY SAYING IS '' IF I CAN'T FIX IT I'M GOING TO BREAK IT TRY'N '' THANKS AGAIN AND LONG ASHES .. JAY THE POOL PUMP MOTOR REPAIR GUY IN LONGWOOD FLORIDA .. HOME OF THE POOL PUMP REPAIR PUPPY, HE'S THE SIGN OF A BARK'N GOOD DEAL
The motor has a themal switch that shuts down the motor f it gets hot. The problem you describe could be that. Also, if the bearings are failing and the motor is very hard to turn, it could be drawing too many amps and tripping the breaker.
I can smell the motor like it is running hot so I think the thermal switch is working fine. I think I need to understand why the motor is overheating. It has been in place with the present wiring for years.
