Olympus m:robe MR-100 Digital Media Player Logo
Posted on Feb 16, 2008
Fatal error oo4
Fatal error service required needed 004
  • sexysacer09 Apr 22, 2008
    my m robe accidentally left my m robe in my bag which went into the washer couple days later i let it charge then call Olympus they said to download something from their site which brought on the system error.
simbaah bell
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Sep 05, 2011
simbaah bell
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
679
Points
Error 004 occurred after i dropped it
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Apr 09, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1102
Points
Fatal system error
service required/004
1helpful
Error 030 fatal error
ecblank.gif What does "Fatal Error" mean? ecblank.gif ecblank.gif ecblank.gif ecblank.gif
ecblank.gif ecblank.gif Summary: Printer has displayed a "Fatal Error" message. This simply means a problem has occurred requiring you to take action. It does NOT mean that your printer has "died". ecblank.gif ecblank.gif ecblank.gif ecblank.gif
ecblank.gif ecblank.gif Your printer display or status monitor may read "Fatal Error". This simply means a problem has occurred requiring action to clear.
A "Fatal Error" does not mean your printer will "die". Fatal Error explanations are not usually found in the User's Guide or Handy Reference Guide.
RECOMMENDED NEXT STEP: First, try turning off your printer then turning it back on. If this does not clear the message or remedy the problem, check to see if your printer is on a power strip (or not plugged directly into the wall). For testing purposes, be sure the printer is plugged directly into the wall. Often, the issue is power-related.
Second, if the issue persists after this, write down the message (including the 3-digit error code number) and email us at "[email protected]" or call Oki Data Customer Support (1-800-654-3282) for assistance.
NOTE: If you see a series of letters and numbers(scrolling across the display) after the 3-digit error code, be sure to write these down also and report them when call or emailing Customer Support.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
1helpful
Fatal system error service required/004
Please reset the player, use the reset key to set the player.
Turn it on and it says error service required/004
if it is a hardware complain its better to give for service else try this method
try to update the firmware and reinstall m:trip software..!!
My OKI printer is giving me a message which reads, "Service Call 106: Fatal Error".
YYYY
106: FATAL ERROR
An error has
occurred which
requires service.
YYYY = the general
cause. 106 = error
number.
Try turning off the
not remedy the
problem, write down
the message including
the error number
“106,” then call your
authorized Oki Data
Service Dealer for
service.
Note: If you see a
series of octets
containing letters and
numbers scrolling
across the display, be
sure to write these
them to the Service
Fuser error. Replace fuser or if no-go, Main board.
2answers
Dear Esperts, I want to install HP C7280 on my XP Pro. The pop up message appeared as follow: "Fatal error during installation Invalid Drive: E: Fatal Error MSI.netdevicemanager01 " Any suggestion to solve...
Sounds like a problem with the installation disk.
Try clicking on this link the download the Full feature software and drivers package
Allow it to install. If it works your done, if not the disc isn't the problem. If that is the case respond back here with any error messages that show up and I will take a little deaper look into the problem
Hope this helps Fixya,
Chris
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&dlc=en&cc=us&product=3204785&lang=en
2answers
Hi I have a Oki c6100dn Printer with fatal error message 173, How can I fix that
unfortunately, a 173 error is a fatal error which requires service, or technical skill on your part. It usually involves replacing the power supply board and fan.
Olympus mrobe
http://www.esnips.com/doc/b15238f2-5133-43e4-b8c4-353375b77088/System_Index
unzip it, drag the System Folder and the Index.mum filedirectly onto your m:robe. then pull it off the dock. you might have topush reset.
and then freshly install the m:trip software from
http://downloads.olympus-europa.com/consumer/mrobe/m-trip/ENG/mtrip_english.zip
aftertht install the firmwarehttp://www.olympusamerica.com/files/oima_cckb/MR100_FirmSysUp_213.exe..beforeinstalling the firmware make sure tht u reset the player ..afterfollowing all the instructions of the firmware try to synch the playerto check whether it detects music and finally restart your m:robe totake effect..!!
Fatal System Error Service Required /004
what the problem is is that the arm on the hard drive is stuck so you need to open up the m:robe and then use a small screwdriver in it and unstick it
1helpful
4answers
HI i have a fatal system error /004
ı have the same problem too.can you help me emergency:S
Error code : 0400001f
fatal system error
Top Olympus Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
Ngoro
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
